I need to know which color wire goes to the capacitor. I forgot to write it down when I took it out.
  • Heating & Co... Master
  • 1,778 Answers
Every manufacture has there own colors. If you look at the wiring diagram you should be able to figure it out. Colors are labeled right on the diagram.
Posted on Apr 26, 2017
What number goes to what color wire
It doesn't work that way! What make/model of fan do you have? How many wires on capacitor? Usually the black wire goes into the L. Always write that info down BEFORE removing the wires & never cut the wires. Also, you have to get the correct switch. Just because it looks the same on the outside doesn't mean it's the same on the inside.
May 24, 2016 | Dryers
Switch broke off of fan and need to replace the switch
Need to know how many wires on the capacitor & what color wire goes into which slot on the switch. DO NOT CUT WIRES!!
Do you know make/model of fan?
Oct 24, 2015 | Dryers
How is a three speed fan switch wired
They are NOT all the same! Usually the black wire goes into the L. Also, you have to have the correct switch! Just because the switch looks the same on the outside doesn't mean it's the same on the inside! Would need to know how many wires on the capacitor & which color wire goes into the switch.
Jul 14, 2015 | Dryers
Where can you buy a fan speed controller for a uc7067rc fan
Could you give us make/model of fan. Also need to know how many wires on your capacitor & what color goes into what slot in the switch.
Sep 24, 2014 | Dryers
How to replace pull chainon a 1um42?
I don't know what fan that is but DO. Not. Cut the wires! Make sure you write down what color wire goes into which slot on the switch. If you can't find the correct switch, Let me know how many wires on capacitor & which slots on the switch they go into. Fanman9952@aol.com
Sep 05, 2014 | Dryers
Fan Switch Change out
Should have written that down when you took out the old one. Anyway, just because a switch looks the same on the outside doesn't mean it's the same on the inside. If you don't find the correct switch let me know. I need to know how many wires on your capacitor And which wire went into which switch opening. usually the black goes into the L.
Jun 25, 2013 | Dryers
I have a Ruud Air Conditioner and need to install a new capacitor, but I forgot how the wires were on the old one. Can you help me in tellilng me which wire goes where.
There should be 3 terminals on the capacitor marked "C" "F" and "H".
A wire from the high voltage contactor goes to the "C".
Another wire from "C" goes to the compressor.
These wires are usually red.
The "F" terminal has a wire going to the fan,usually a brown wire.
The "H" has a wire going to the compressor,usually yellow.
There should be a wiring diagram on the control box cover identifying the terminals,colors and number of wires.
Jul 25, 2011 | Heating & Cooling
Split AC capacitor fused.
You need to trace the wires back to the device ie compressor, the fan now then write the color down. Note the capacitor has two different sides to it herm which is compressor and fan. then the common in the middle. Take the compressor wire should only be one and connect it to the herm. Now take the fan should only be one again and connect to fan. two devices connected. You might have two more wires and they go to the common. If you need any more help just get back to me. ken
May 09, 2010 | Samsung AW0603B Air Conditioner
I'm looking to replace the fan switch for a hampton bay ceiling fan, but I don't know where the wires go. The colors of the wires are black, yellow, purple, and orange, and the slots on the switch are L,...
This is fairly simple.
Assuming you have a black brick capacitor, and assuming you have the correct switch, for capacitor speed control.... (if you don't you will not blow anything up)
On your capacitor, there should be a set of two wires which are the same color. Black goes to L The two wires which are the same color, one will go to position 1. The other two wires, will go to 2 and 3. On the capacitor it should have some numbers and crude diagram with the color of wire on it. The wire with the highest value (say it's 6) will go to position 2 and the lower value will go to position three.
If you only have one small capacitor in the switch housing, (usually a red and white wire one) then you have a winding taps speed control. If you have a capacitor type switch, you can burn out your motor, as on the second position of that switch it activates both 2 and 3 (or medium and low) Be sure you have a switch which operates as such L+1 L+2 L+3. If you have the proper switch, then all you need to do is connect the black wire to L and then randomly place the other three wires into the switch and test it. Most likely the speeds won't be right (it might go medium, low, high) if it does, then just move the wires around until it goes high medium low.
Mar 31, 2010 | Oasis Hunter 54' Ceiling Fan
COLEMAN EVCON/MDL #BPCHO361BA
one wire from one leg of contactor to "C"terminal on compressor. One wire from other leg of contactor to "R" terminal on compressor. One wire from same terminal on contactor as wire to "R" goes to capacitor (grey or silver cylinder) "C" terminal. One wire from capacitor "herm" terminal to compressor "S" terminal
Jun 18, 2008 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
