Please help also with personnel training n6 2016 and 2015
Error e000750 for Canon or2520 copier need a solution
This error code occurs , when the printer transmit fax in error correction mode but could not got the Rx. signal.
This error may blocked on SSSW 01, select bit-0(1-for out,2-not out) under service mode.
If you are experienced enough do it else take the help of trained personnel.
Feb 28, 2015 | Canon Office Equipment & Supplies
How do u repair sensor on olympus fe 340 camera
You don't....sensor repair (actually replacement) can only be done by trained service personnel.
Aug 02, 2011 | Olympus FE-340 Digital Camera
Forgot my password for my samsung smiley phone
Contact a trained service personnel and get it flashed and update the firmware.
no other solutions.Done
Jan 11, 2011 | Samsung Cell Phones
How to change the battery
and if you try to do it yourself you will learn why they suggest that! Screws in strange places and many little items that are difficult to get back in place. Also the battery is unique and not available on the common market.
Please rate my help++++Thanks for using FIXYA
Jun 06, 2010 | Sony NV-U73T GPS Receiver
Quatz watch not running even when i put a new battery in
Several things could have caused this. First if the battery was not installed properly or by a trained technician the movement may have been damaged. We see this all the time with watches taken to the 'Mart' stores or to Jewelers and the little places at the mall. None of these places have trained personnel and they damage a lot of watches.
The other possibility is that the lubricants in the movement have dried out and are now gummy and act like glue holding the gear train in place so the power from the battery cannot get it to move.
Both of these problems require professional help. A watchmaker can repair either of these situations.
Hope this helps,
Yellowstone Watch, Inc.
May 20, 2010 | Watches
2006 vw tdi Jetta DGS Clutch engages when brake is applied
Take this to a garage ASAP. This is a dangerous condition that needs investigation.
I recommend most brake defects are checked by trained personnel - It's not worth the risk is it ?
Aug 04, 2009 | 2006 Volkswagen Jetta
Screen quit working
Very often it is the cabling that connects screen to main board. This is available as a spare to replace - but I warn you is VERY fiddly to do.
Worth a repair by trained personnel though.
Aug 04, 2009 | Canon PowerShot A85 Digital Camera
Hi Gunawan,
The error 'L6' is usually an indication of problems with the Laser Unit in the copier.
Unfortunately the unit will have to be replaced and can only be done by trained personnel.
Contact your closest Sharp Dealer for assistance.
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
