We have a 42" HCT 1080p that has a white line running down the screen. Tried different HDMI cables, same thing. Can it be fixed ourselves & what part would we need?
SOURCE: LG 42LB5DF Horizontal lines when first turning on
I got my main board replaced under warranty and this fixed the problem.
Posted on Apr 25, 2008
SOURCE: Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Posted on May 08, 2009
  • 44 Answers
SOURCE: No signal when outputting 1080p on ps3
put your ps3 in standby (solid red light), and then hold the power button until it beeps a second time. then the picture should come up.
Posted on Jun 23, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here:
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds. That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
Posted on Sep 26, 2009
I connected the cable box to my LG tv with new HDMI cables and the picture is noticeable smaller than the size of the screen. Before, I had the cable from the wall connected directly to the tv and the...
Your cable box and TV are set to different resolutions. Check the setup on both and make sure everything is the same (ie 720p to 720p or 1080p to 1080p) Make sure your cable box can give you 1080p (Nice set, BTW!!). HDMI is supposed to automatically take care of the settings, but it does not hurt to double-check.
Depending on the manufacturer of the cable box, there may be screen setting for "letterbox" which should be selected.
Some TV channels, when redirected through a cable box, simply will not display full resolution (1080p) programming. Your cable TV provider can tell you which channels are displayed in high resolution.
Finally, make sure your cable provider gave you the correct box. Older boxes are not capable of providing 1080p resolution, and since you own a 1080p set, you deserve nothing less!
Jan 30, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
Playstation 3 Flickers when set to 1080P on 32LG70
This may help... open Display settings, scroll down to the Deep Color option... switch it from automatic to off. So far this is the only solution that I have found
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
1080p doesn't work on PS3 and LG 42 inches LH4000
You appear to be correct. HDMI Timing issue with PS3.
1. Try a different cable
2. Try a shorter cable
3. contact TV manufacturer and report it.
I am guessing this may be corrected by replacing the cable. HDMI cables use different gauge(Thickness) wires and different shielding, so with some inferior cables there may be noise. This will cause picture problems. Don't let name like "monster" fool you, you Must try a different cable. If this is a TV problem, I would guess 100% that the TV manufacturer is aware and already created a fix if so. PS3 is so popular as the choice Blu-ray player that it is tested will all products sold. Almost used as a baseline for correct operation with BluRay and HDMI devices.
Jun 08, 2009 | Televison & Video
PS3 static on screen
It sounds like you're carrying interference to your TV. Try moving you station away from any power source. Make sure your hdmi cable is away from any power as well. This may also be a ground issue. Plug your ps3 power brick into a different outlet.
May 14, 2009 | Sony PlayStation® 3 (80GB) Console
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
New tv and hdmi
Mar 22, 2009 | Sony BRAVIA KDL-40V3000 Television
Screen randomly flashes black
First and foremost you need to change one of two things. Either your video output settings on your xbox 360, or use an hdmi cable as opposed to component cables. Component cables are only designed to output video up to 1080i, not 1080p(big difference). So if you try to run a output signal of 1080p with cables only made to send 1080i, you will have picture issues.
Nov 23, 2008 | Sharp Aquos LC-32D40U Television
I have the same problem on my 42 inch LG 1080p and I read in the manual this could be due to interference. I have messed around with my other electronics but couldnt find the problem. I do live in a apartment so I dont know if maybe another persons electronics are causeing it or not. I will be contacting LG regarding this issue although it wont get me anywhere im sure, but I will post again If I should find a soulution.
Sep 29, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
