Question about CA Computers & Internet
Replaced two Gryphon wireless scanners, they are charged but won't scan when trigger is pulled. What to do? Teacher Librarian in Long Beach CA
2 Suggested Answers
deerdesign
SOURCE: Gryphon D100
You can find a list of all Datalogic Repair Centers here: http://www.datalogic.com/_vti_g2_suppARC.aspx?rpstry=12_ simply choose your country in the selector on the bottom of the web page. Enjoy, Fabrizio
Posted on Mar 06, 2007
Hi, I need to know how to program the DB Power barcode scanner model # BCE0008
Unfortunately, this is all I can find for instructions.
Operation Instructions:
1. Connect the USB receiver to the host (e.g.: PC)
2. Pull the trigger to start the scanner. It works on two beeps.
Notes: 1. The charging port on the scanner is for battery charging only. Do not connect it to data cables.
2. The LED light at the scanner bottom is on and red under charging and off when charging is finished.
3. During working, the scanner will auto shut down in case of not in use for 20 second.
4. The receiver was paired to the reader at factory. Do not pair again unless necessary. When self pairing is needed, please first read the code CHANNEL SETTING. (Before setting, please reset the receiver until the light turns long green. Reset it to the light off when setting is finished.
Package Including: 1 x Wireless Barcode Scanner 1 x Receiver 1 x Charging Cable 1 x Instruction
Sep 08, 2016 | DBPOWER 2.4GHz Wireless Handheld Automatic...
HOW I WANT TO DISABLE ENTER AFTER I SCAN BARCODE..... I USE SCANNER MODEL GRYPHON GD4400
Just download print the GRYPHON quick reference guide (print on laser printer without zooming) and program the scanner to factory default.
Otherwise, you will need to download the FULL reference manual. Then print out the relevant programming barcodes that will remove the last character.
Dec 14, 2013 | Datalogic Gryphon Computers & Internet
]c1 : where to find the code to eliminate ]C1 when reading barcode EAN128 ?
Page 80, Section GS1-128 AIM ID Section of Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English)
Manuals
Aug 12, 2013 | Datalogic Gryphon I GM4100 Barcode Scanner...
Gryphon gm4100 ean 128 ]c1 identifier
1. Download Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English) Manuals .
2. Go to Page 80, Section titled GS1-128 AIM ID.
a. Scan the Enter/Exit Programming Mode code.
b. Scan the GS1-128 AIM ID=Disable code.
c. Scan the Enter/Exit Programming Mode code.
Feb 22, 2012 | Datalogic Gryphon I GM4100 Barcode Scanner...
Scanner dies during process of scanning, then i have to unplug usb and restart
This can occur when a scanner is set up incorrectly on the computer or register you have it plugged into. How to fix this varies wildly between systems.
Feb 28, 2011 | Datalogic GD4130-BK: Gryphon D4130...
When scanning green light goes on beeps and nothing else happens.
Here's a link to the page where you can download all the manuals, software, etc for that unit. You might need to cut and paste it into your browser's address bar. Godd luck!
http://www.scanning.datalogic.com/sitefiles/gryphonlgd4300.aspx
May 20, 2010 | Datalogic Gryphon L GD4300 Barcode Scanner...
Loosing beam
I'm 100% positive that your scanner is need to be repaired, or if it's still guaranteed please change into a new one.
Aug 01, 2007 | Datalogic Gryphon M200 (M200/SERIAL)
Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
May 31, 2007 | Datalogic Gryphon D200 (901661076)...
Gryphon D100
Feb 23, 2007 | Datalogic Gryphon Cordless M200...
Computers & Internet Logo
24 people viewed this question
Top CA Computers & Internet Experts
john h
Andrew Taylor
Andrew Taylor
richie46
Are you a CA Computer and Internet Expert? Answer questions, earn points and help others
