Question about The Computers & Internet
My duke 200 is not starting . It's showing error JG_1.7.2 Can anyone tell me what must be the reason for that ,?
The check engine light came on my KTM duke 125 after I was driving it in the rain what should I do?
Hi, Peleg it should be noted that the reasons your check engine light constant or flashing, will or will not start, turns over or not conditions varies from the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work or event IE: adding accessories, electrical curiosity/adventures, laying bike down/crashes, rainstorms/bike washings just before EFI light issues started can be significant hints/aids into tracking down the gremlin, also carry the appropriate jumper wire to access fault codes to reduce the risk of being stranded or towed, that being said the usual suspects are:
1. Faulty Fuel Pump, fuse or system relay switch.
2. Battery starting to fail due to old age/damage, perform a load test.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
5. Broken wire or worn insulation exposing wire to a ground situation especially inside wire harness at tight bends around fairing brackets, under dash panels, under fuel tanks over cylinder heads etc. Many harnesses are open on the ends that will allow water to enter and accumulate at v-bends.
6. Check for generated fault codes.
Dielectric grease and contact cleaner are your best friends for wire/cable/harness connectors, look for corroded, broken, or loose pins/sockets.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Ktm duke 125 Check Engine
https://drive.google.com/file/d/0B-UgQx8CVp8JemN0Z2FRQnFQLU0/view
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 125 DUKE EU Owner Manual KTM DUKE 125 200 2012 Workshop Repair Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 04, 2016 | KTM 2013 125 DUKE
I don't understand the blunder when Percy Wainwright calls Hal gracious in Lord John and the Brotherhood of the Blade?
Percy calls Hal "Your Grace", the proper way to address a Duke. However, for reasons that are too complicated to go into, for years Hal has rejected his title as Duke, and insists that others use his lesser title of Earl, for which the proper term of address is "My Lord".
Sep 04, 2016 | Outlander (2014)
I turned on duke 200 and as soon as i removed the stand! The display went off. Since then, nothing is shown on the display and the bike does bot even start. Just wondering what could be the fault?
Hi, Malkeet and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below Good luck and have nice a day.
KTM Duke 200 refuses to start What do you think can be the problem
HELP Starting problem KTM Duke 125
What to do When Your Motorcycle Won Start
2012 Duke 125 200 Repair Manual pdf
Apr 17, 2016 | Motorcycles
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Programs with variable number of arguments
To start points and lines are not shapes, and a triangle is not representable with a single function, therefore you need a function to draw shapes , given a number of points as parameters, and one to draw math functions (lines etc.).
Here is an example: Draw Line, Ellipse, Polygon ...
From website above, here is script in JS:
"<script type="text/javascript">
function myDrawFunction()
jg_doc.setColor("#00ff00"); // green
jg_doc.fillEllipse(100, 200, 100, 180); // co-ordinates related to the document
jg_doc.setColor("maroon");
jg_doc.drawPolyline(new Array(50, 10, 120), new Array(10, 50, 70));
jg_doc.paint(); // draws, in this case, directly into the document
jg.setColor("#ff0000"); // red
jg.drawLine(10, 113, 220, 55); // co-ordinates related to "myCanvas"
jg.setColor("#0000ff"); // blue
jg.fillRect(110, 120, 30, 60);
jg.paint();
jg2.setColor("#0000ff"); // blue
jg2.drawEllipse(10, 50, 30, 100);
jg2.drawRect(400, 10, 100, 50);
jg2.paint();
var jg_doc = new jsGraphics(); // draw directly into document
var jg = new jsGraphics("myCanvas");
var jg2 = new jsGraphics("anotherCanvas");
myDrawFunction();
</script>"
Oct 25, 2008 | Computers & Internet
!SisRegistryServer error
We have 2 problems :
1-Application
!SisRegistryServer
Reason Code
ucmp
Reason number
0
2-Application
Application installer
Reason Code
KERN-EXEC
Reason number
Nov 13, 2007 | Sony Ericsson P990i Cellular Phone
Computers & Internet Logo
144 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
