Question about Garden
What size/ length of deck belt for 2006 lt1042
  • 148 Answers
SOURCE: need deck belt size yardman model numbera42707
I would suggest downloading the owners manual from www.managemyhome.com and it will tell you what size belt you need.
Posted on May 19, 2009
  • 133 Answers
SOURCE: I have a 1995 murray lawntractor model#42816B.The
Have you tried going to www.murray.com and then find a dealer. Call them and ask if it is right belt. If you have the old belt there should be number stamped on it. If you have the number and you can't find a belt try a mower repair shop and they can cross ref it and get new number if it has been changed.
Then when you put the new belt on make sure you have the right belt and then it should be fairly easy to route the belt if you put the back of the belt (flat side) up against the larger in height idler pulleys and the smaller (v) in the smaller pulleys. The belt should be snug when on properly.
let me know if this helps.
Thanks
roundo4
Posted on Aug 01, 2009
  • 33 Answers
SOURCE: I need a deck belt for a cub cadet 2166 what
http://www.cubcadet.com/webapp/wcs/stores/servlet/category1_10051_14101_1100505_Y_-1
Posted on Aug 21, 2009
rtpflh
  • 546 Answers
SOURCE: Have a 2006 145 automatic riding mower. Belt keeps
idler or adjustment pulley bearings worn allowing belt to ''run off''as it wobbles.stays on.check spring tension of idler.
Posted on Sep 20, 2009
2strokeguy
  • 183 Answers
SOURCE: what is the deck drive belt length for this mower
Your mower uses the #144200 belt by A.Y.P. This belt is 1/2" by 88.3" You must use a wrapped belt for this application. The #144200 is available through www.searspartsdirect.com and will also be readily available at your local repair shop.
Posted on Sep 10, 2010
I have a 1990 toro wheel horse classic 312 8 lawn tractor, it has a 42 inch side discharge deck, What's the deck drive belt size of this mower, model 31-12K801, I have searched for hours
If the belt is in one piece, put a chalk mark on the back of the belt and measure the length by running a tape measure from one side of the mark all the way around the belt until the mark appears. Take that measurement, subtract an inch for stretch and that number is the number of the belt you need. If it's broken in two, not three, then simply measure the length of the belt.
May 28, 2016 | Garden
Whats the length of the deck belt
the original length of deck belt is Deck Length 96 1/2" Type Covered Width 1/2". Fits Model. CUB CADET : LT1040 and LT1042, 42" ...
and pls vote me as helpful if it is
Jun 23, 2015 | Garden
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Need to know what size deck belt it takes for a roper lawn mower the model number is yT140Dr
Electrolux 532106085 (replaces 106085X) BELT-V.79.1.MWR : This is the OEM belt number for the yT140Dr mower deck. Length = 79.1" ; Width = 0.5" (1/2").
Welcome to VBELTS4LESS COM Belt Supplier For Industrial Belts Lawn...
The above link is for VBELTS4LESS, an excellent web site for belts. I've used their belts for two mowers, and the belts are excellent...
Jun 15, 2014 | Garden
Stanton str8-20 belt size???
HI,
If you are unable to find your turntable measure the nearest length, if you are unable to find the exact length (as belts stretch slightly with use and age) choose the nearest shorter length. To check drive belt length for most type full platter decks remove mat and lift platter off center spindle (remove circlip if fitted), turn platter over and measure the circumference of the drive hub and deduct 5-10mm to determine correct length and tension
OK
Dec 11, 2012 | Audio Players & Recorders
Vee belt length
hello there eddie here i am a dealer if you could give some more info i can help mod# of the husqvarna
Jul 27, 2012 | Husqvarna Garden
Belt comes off. idler pulley bracket doesn't seem to have enough tension on it. Bracket spring is still on. Maybe wrong spring? Just bought new belt and it went on way easier than old belt . is...
the new belt should be a hair smaller than the older one thus being tighter to put on, either the new belt is the wrong size or you don,t have the tensioner spring tight enouph, did you have to take it off at some point and just not get it back in the right hole
also make sure your routing the belt the right way around the pullies,if all that is good ten check the length on the belt
sounds like its just a matter of correct routing
Jul 31, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Model no. 917257660 need belt size for drive and deck
The part number for the drive belt is: 140294 the size is Length: 82 1/4", Width: 1/2", Type: Covered
The part number for the mower deck is: 140067 the size is Length: 82 1/2", Width: 1/2", Type: Covered
They are very similar belts so don't get them mixed up the springs on the clutch pulleys may not be able to compensate for the slight difference.
Good luck, if you find this helpful please vote yes. Thank You!!
May 11, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a sony shelf system with combination cd and cassette - bel
Sorry, we have no belt listing for your specific model, but we do likely have what you need........
If you still have the old belt intact:
> Lay it out flat on the table
> Pinch it at both ends & straighten the belt but don't stretch it.
> Measure the length & then double it and choose or we will recommend
a size about 3-5% smaller.
Old belt too far gone to measure:
> Just use a piece of string and thread it temporarily in place of where the belt goes.
> Then measure the length of the string and Email us the exact length (inches). Along with your EXACT model number.
If your belt has a round or square cross section, please give us the thickness as well. We can assist
you in choosing a belt usually 3-5% smaller than the length you measured.
....from the turntableneedles.com site
Jan 18, 2009 | Sony CASSETTE DECK Single Dual Cassette...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
