Question about Electrolux Vacuums
My Electrolux epic tank vaccum, when I turn it on ,after a few seconds it shuts off and the bag symbol light is on. I put a new bag and filter in and it stills do the same thing
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
  • 13 Answers
SOURCE: Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Posted on Oct 03, 2008
  • 333 Answers
SOURCE: Vacuum won't stay on
When you open the canister you eill see a little rubber hole that senses when your bag is full. This must be clogged. If you have another vac try to vacume all the dusr from this hole and any other opening inside the vacume that you can reach. I hope this helps. Don't forget to rate this answer.
Posted on Feb 07, 2009
  • 73 Answers
SOURCE: Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Posted on Aug 27, 2009
SOURCE: i have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Posted on Jan 30, 2010
Why does it start, then immediately stop and bag light comes on?
My epic 6500 starts for a few seconds and turns off. With the filter light on. I take out the filter and it still does it. It only stays on if I cover the filter hole with my hand. Any solutions.
Oct 23, 2015 | Electrolux Epic 6500 Vacuum
How to fix
The machine may be over heating.Check the hose and power head for a block.Or,put in a new bag and suck in a few pieces of tissue to coat the lining of the bag....Chris
Aug 01, 2014 | Electrolux Epic 6500 Vacuum
What is the round dial by the bag symbols for on the electrolux epic series 6500 sr for
the dial sets the type of dirt you are vacuuming.Fine dust allow bag to fill before shutting down.The best is to turn it to the middle,this should allow bag to fill properly before shutting down...Chris
May 01, 2014 | Electrolux Vacuums
Just given what looks like a brand new Electrolux Epic 6500 series canister vacuum. I have plugged it in, there is a bag but it won't turn on. Is there something I have missed??
The Epic 6500 was actually manufactured in 1992 so in no way can be considered brand new.
First, make sure the plug symbol beside the dial is lit. This indicates the vacuum is getting power. If it doesn't light, there's a problem with the cord or the connections.
Second, turn dial on top of the vacuum so the smallest dot lines up with the arrow. This will allow for vacuuming finer dust for longer periods of time.
Third, check the afterfilter on the back of the machine. You do this by pressing the tab on the base of the tool caddy (in back) and lifting off. If the filter is dirty it needs replaced, or at least removed. Try the vacuum.
4. Detach hose from the vacuum and turn on. If it does, hold palm of hand over hole. If it shuts off, the control valve assembly is bad and needs replaced. The tubes connected to it will probably need cleaned. For this, It will need to be taken to an authorized Aerus Electrolux store for repair.
There are a few other things that could cause the vacuum to not run. See the following page for more information:
http://www.fixya.com/support/r7367127-electrolux_epic_6500_trouble_shooting
Jan 06, 2011 | Electrolux Vacuums
I have the electrolux epic 6500 sr. when i
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
With a new bag -after turning vacuum on, it shuts down
This vac is prone to a control valve failure with the exact symptoms you describe. There is a dial valve on top of the machine designed to regulate how full the bag will get. The valve which sits underneath the dial on the vac likely has a broken plunger and will need to be replaced. Take it to an AERUS Electrolux dealer / shop for an experienced tech to work on.
Sep 13, 2009 | Electrolux Epic 6500 Vacuum
What is the symbol above the "change bag" symbol?
When the bag is full, the "full bag" light will come on and will turn itself off. Replace bag (make sure there is no clog) and try again.
Hope this helps.
Aug 17, 2009 | Electrolux Epic 6500 Vacuum
Feb 07, 2009 | Electrolux Epic 6500 Vacuum
Model EL7020 will not stay running!
Try turning the knob on top of the machine all the way to the right and try it again
Dec 04, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
