Question about Uniden Lands Phones
Uniden model 9280, the question I have is why the four-way function key doesn't work. we just ordered and put new batteries in yesterday and they register full.
  • 17 Answers
SOURCE: need manual for uniden tru 9280-r
hope this is what you looking for.
Enjoy :-)
Posted on Aug 27, 2009
SOURCE: Handsets won't register - locked in one state
Purchased new base unit.
Posted on Dec 25, 2009
  • 132 Answers
SOURCE: Uniden Atlantis model#atlw27 057782. Unit dead
probably battery contacts or dead board.
Posted on Jan 13, 2010
Testimonial: "Thank you to the Tech team. Have sanded battery contacts with 1500 paper; no change. Rick"
SOURCE: I have a Uniden TRU9480 5.8GHz Phone and the
I found this elsewhere:
I've fixed this by taking the phone apart, finding where the pressure pads are under the button. I glued a small piece of aluminum foil on to where the pressure pad is. Aluminum foil is a good electrical conductor. It's a delicate process. I don't recommend doing this unless you know what you're doing. But if your handset is already dead/useless, give it a try. Put everything back together and the buttons work again.
Posted on May 18, 2010
SOURCE: function key doesn`t work with windows 7 installed
My Vaio model is VGN-FS840 and after I formatted by laptop, my function key is not working, what shall I do to make it run? Can I download the driver? is it available in websites?
Posted on Sep 24, 2010
Answering machine will not pick up after four rings
What model Uniden 5.8GHz phone/answering machine? Exactly what does it do after four rings? Does it just drop the call or continue to ring? Is the answering machine turned on?
Nov 19, 2013 | Uniden 5.8GHz Expandable Cordless Phone...
How to turned off silent mode
With the phone in standby, try pressing and holding the # key on the handset for 5+ seconds. This toggles the silent mode for the D1660 between "always on" and off. If this doesn't help, check the Ringer volume. (This can be set by pressing the volume + button with the phone in standby on some models.)
If this doesn't work, please add a comment with the specific model Uniden DECT 6.0 phone that you have? There are several. Manuals for many Uniden DECT phones are available from their customer support site: . The manuals are in alphabetical and numerical order.
I hope this helps.
Nov 22, 2011 | Uniden DECT 6.0 Cordless Telephone...
I blocked a telephone number by mistake. How do I unblock it? Thanks
Hi ther here is some steps if it works..Enter the last four digits of your phone number on your cell phone PIN screen.
Enter 9999, and if that doesn't work try 1111, and if that doesn't work try other four-digit numbers you may have entered.
Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number which is under the battery. Re-insert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen
Call your service provider and request the unlock PIN if none of your attempts so far have worked. You will have to prove you are a customer by stating your cell phone number..
Finally See a cellphone technician..
Jun 19, 2011 | Uniden Cell Phones
Need manual for uniden tru 9280-r portable phone
Enjoy :-)
Aug 27, 2009 | Uniden TRU9280-3 Trio Phone
Round button in middle quits working.
Sounds like you may not be selecting the right menu buttom. The soft keys are right below the screen. these three buttons function change depending on which screen you are viewing. I have copied the instructions from the manual below. You must select phonebook to view the phone book using the round button. You must select volume to change the volume with the round button.
The Standby Screen
When the phone is in standby, the handset display shows the following items:
Ringer off icon (when the ringer is off)/ day of the week and time / battery iconHandset ID and BannerNumber of new Caller ID calls received (If there are no new Caller ID messages, the Handset ID appears here.) SUN 12:00A Handset #1 New CID: 5REDIALMENU
Using the Four-way Function Key
Your handset has a four-way function key that allows you to move the cursor (or highlighted area) on the display and access the most commonly used features at the touch of a button. By moving this key to the left, you open the Phonebook. Move the key to the right to access Caller ID information. To use this four-way key, place your thumb over the key on the station and move to the four positions to get the feel of how it moves and operates.
Using the Handset Menu
To open the menu, press the MENU soft key. Highlight the option you want by pressing the four-way function key. This will move the cursor; the option currently highlighted appears in reversed out text. Select the highlighted option by pressing the OK soft key. To exit the menu and return to standby, press [].
If you do not press a key within 30 seconds, the phone will time out and exit the menu. When setting Date and Time, the time-out period is extended to two minutes.
Note: For GLOBAL SETUP and DEREGISTRATION menu options, make sure the line is not in use and the handsets are within range of the base. 123abcdefView the phonebook Four-way Function KeyUpView the Caller IDDown123abcdefView •
Jan 31, 2008 | Uniden TRU9480 Cordless Telephone
Lands Phones Logo
41 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
