Question about Hughes HACC-TR2 Remote Control
The remote quit working. The tivo box works ok,
I have 2 remotes and the box will not respond to either if them. They were working fine, and all of a sudden quit. I have tried cleaning the sensor , disconnecting the tivo, and switching all the remote batteries.
  • bruchcat Jul 25, 2009
    no- the setting for the remote on the menu are only for changing it to use with the tv, or for sound.
  • Dana Newcombe
    Dana Newcombe May 11, 2010
    Is it possible that someone else got into your set-up menu and changed the remote settings?
    President:
  • 1,564 Answers
I hope the tivo is still under warranty, it sounds like it's time to call them, sorry I couldn't be of better assistance.
Posted on Jul 25, 2009
  • 82 Answers
You can check the operation of a remote control with a cell phone camera. Point the remote at the lens and press buttons, if you can see light, the remote is ok, and you have a problem with the TIVO.
My Vista plasma tv has no pic. The remote won't work and it turns off by itself
The first thing you should do is unplug the tv from the electrical outlet for 2-3 minutes, then plug it back in. Hopefully it will "recycle". If that fails, check the connections and settings on your TiVo/cable box. Chances are that the remote is fine, but the tv is simply not responding to the infra red signal. As for it turning off by itself, get out the original tv remote, go to menu, then try to search out a place where there is a timer setting. Could be that it got activated accidentally. You also may want to try the "recycle" thing on the cable box itself. Good luck!
May 23, 2016 | Televison & Video
My remote as stopped working my tivo box
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
If remote control is working OK, check and replace the remote sensor inside the TV. Contact any service technician.
Aug 13, 2014 | Tivo C00210 Remote Control
Why wont my pillow remote work on my virgin tivo box?
Oh boy. here is the problem. i have also a 106240 IR/UHF receiver/transmitter that changes the channels in the satellite box from another room so i can watch them in a second tv at channel 4. the original remote for the 106240 is broken and i bought another UHF remote #153638. So i need to program the new remote to work and link with the 106240 receiver, NOT the satellite box or the tv. Is there any expert here to enlighten us how can be done ? Very simple question :how to program the remote 153638 to link with the 106240. Thank you in advance
Dec 22, 2012 | Tivo Televison & Video
Trying to set up tivo series 2 without remote
There are different codes depending on whether the Tivo was set to respond as a specific device (1 or 2) on the remote or by standard default (device 0). Also, typically each universal remote has its own code for each device, which is specific to the remote, not the device you wish to control. For the $20.00, it might not be a bad thing to simply buy a new universal remote that is capable of controlling a PVR (There are many good ones out there).
Mar 15, 2009 | Humax DRT400 TiVo 40-Hours Video Recorder
Need code for Brookstone remote to work W/ Direct TV TIVO receiv
Sense you do not know the make of the receiver I would do a code search. This is how you do it.
Automatic Programming
With automatic programming, the remote control tests all the codes available
on the Code List and assigns the correct code for the selected device.
Although this method can be more time-consuming, it eliminates the need to
look up codes and enter them manually.
1. T urn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
remote control is in programming mode.
3. Press and release . The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL + or CHANNEL - after the device turns on.
6. Press any other button. If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
Good Luck and Please Rate FixYa!
Dec 31, 2008 | Brookstone 538744 Remote Control
TIVO Remote Control Problem
A similar problem happend to me. Buying a new remote fixed it - for about three weeks.
Maybe your new one will work longer.
Mar 06, 2008 | Tivo DirectTV Remote Remote Control
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Hughes HACC-TR2 Remote Control Logo
203 people viewed this question
Top Hughes Televison & Video Experts
Jim London
Jim London
Electro Med Services...
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
