Question about Whirlpool Microwave Ovens
Fan not working on Whirlpool microwave Model MH2175xss1
Turntable works, the unit heats but after a few minutes it quits heating. I suspect that is because the fan doesn't work. Fuse was good, but replace anyway. What can I do next?
  • 229 Answers
What do you mean "fan doesn't work"? Magnetron will over heat without fan.
Posted on Sep 14, 2017
  • 9098 Answers
SOURCE: Whirlpool Gold Microwave Model GH7155XHS
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:
You can find helpful exploded view diagrams and order parts by entering your full model number here:
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
Posted on May 09, 2008
  • 9098 Answers
SOURCE: Whirlpool Microwave No longer Heating Food
The most common cause of that is a shorted or blown high voltage rectifier diode.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:
More info here:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Jul 04, 2008
SOURCE: Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Posted on Jan 01, 2009
  • 1199 Answers
SOURCE: Over the range Frigidaire Microwave not heating. Model FMT148
This is a sure sign that the MAGNATRON needs replaced (this is what heats up the food) if every thing else works but food not cooking! 99% of time it is the magnatron!
Please rate answer!
Posted on Jan 13, 2009
  • 9098 Answers
SOURCE: GE XL 1800 microwave light and fan operate but no heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
(if it's not shorted or burned, it's probably okay)
If it's within the magnetron portion of the warranty (5-9 years) but out of the original full warranty (1 year), G.E. will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's within the mag warranty, G.E. should send you the magnetron to do it yourself. Call them at 888-239-6832 with your model, serial, and manufacturing date.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a GE-authorized servicer.
You can find a GE-authorized servicer by calling GE Appliance Service at 1-800-848-7620 or here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Mar 02, 2009
Fan failure /Intermittent heating
quite likely your microwave is trying to prevent it self from self destruct, because if the fan is not keeping the electronics components cool enough while its running the high limit thermo will disconnect power from the heating circuit, if the fan is not working it should be replaced , that's a techs job.
Feb 12, 2014 | Microwave Ovens
After approx a minute a regular squeak begins, occasionally missing a beat.Heating is fine.
If the "frequency" of the squeaking is a low frequency, the I would suspect the turntable motor or stirrer motor (if so equipped).
If it is a higher frequency, I would suspect the cooling fan or hood fan motor.
Dec 11, 2012 | Neff H7871 Convection/Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
It quits heating after a couple minutes and sounds
replace the fan otherwise your microwave cell wil burn out, the safety comes on because the cell become to hot. no colling of microwave cell.
Feb 15, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Not Heating. Fan, turntable, light working.
I would definitely suspect the door locking mechanism in this case. If it was the sensor it would start and then stop within a short time.
The starter switch should click if you have the door open and time it for 01.seconds and press start. So that is the secon component to think of.
Nov 26, 2009 | Sharp R-930AK Convection/Microwave Oven
Oven does not heat food.
either the h.v. diode,h.v. capacitor or the magnetron tube are suspect here due to the no heat condition you have
Oct 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool MH1140XM: has power, but no heat, turntable not spin.
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
May 11, 2009 | Whirlpool MH1140XM Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it:
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
