Question about Dryers
CAn the Casablanca Table fan Model 1928C be repaired
2 Suggested Answers
SOURCE: Casablanca stealth fan light scrapes against blade surround
I had same problem with a Casablanca Stealth fan purchased 10 years ago. As suggested by mrfanman2u, I removed the light plate (3 screws) and an additional metal plate (3 screws) with a phillips screwdriver. The flywheel was now exposed. I then loosened the Allen set screw on the flywheel with an Allen wrench and pushed the flywheel further up on the motor shaft. After tightening the Allen set screw and reinstalling the 2 plates the problem was fixed!
Thanks mrfanman2u.
Posted on Oct 23, 2011
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    Tip
    Casablanca Table Fan, DOA
    If your Casablanca Fan (1928D) Table Fan has stopped working completely, or stopped in the middle of oscillating, it might be the internal AC wire that runs up the middle of the fan base, that is broken internally. First, make sure the fan is not plugged in. You have to take the whole fan apart from the front. Check for continuity on the white and black wires that run to the motor. You may have to pierce the black and white wires with a pin to check them, because they are wired directly into the motor. These two wires have a black jacket covering them that can be pulled off if you find an open wire. Either one of these wires can break internally because of the back and forth movement. Cut the wires close as necessary to the motor to make the splice. Solder and use heat shrink insulation and route the new wire back down through the base and splice them where the original wires were. I used a piece of electrical cord with white and black conductors that was cut off an appliance that was dead. It was the same size as the original so it fit well. Please note, this repair requires electrical and mechanical knowledge. You have to take the whole fan apart to do this repair.
    on Apr 21, 2014 | Casablanca Fan (1928D) Table
    How do I op beeping of my Casablanca stealth fan Bulb is burnt and I removed he burnt bulb. would not top annoying beeping
    Replace the bulb. If you are going crazy while getting a new bulb turn off the breaker for the room. A serious design flaw, I would complain to Casablanca if you have the time.
    Oct 05, 2014 | Casablanca Fans Casablanca Contemporary...
    Casablanca zephair
    The on Zephair came with the old intellouch control,which is a special control for that fan. If that is what you have then call 1-800-715-0393 with model# & serial#
    Mar 24, 2013 | Casablanca Fan 1928C Zephair Satin Brass...
    I have a 16 year old intelitouch fan from Casablanca. I was trying to change the light bulb, but after turning off the power to change the bulb, the power would not return to the fan. I have two wall...
    I have a casablanca intellitouch ceiling fan and if you change a bulb while the unit is powered on you ruin the control board. The control boards are expensive but easily replaced by a diy-er. I think I have encountered this problem twice. These fans are very well made and in the past I decided it was worth repairing. However with the new fan technology out there it would be wise to shop around and weigh your options.
    Jul 10, 2012 | Casablanca Fan Dryers
    I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
    yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
    Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
    Casablanca Intellitouch Fan was working fine.. Then only the light worked and fan switch made a quick bleep and started the blades moving but then both light went off and fan stopped. Now nothing works and...
    Sounds like either the IT wall switch has malfunctioned, OR the IT board inside of the fan has shorted out. This is actually a fairly rare problem with the boards and you may get it covered under warranty. Try calling Casablanca. This fan is worth repairing rather than buying a new one.
    May 15, 2010 | Casablanca Fan 3245T Ceiling
    Who makes Heritage Ceiling fans?
    unfortunatly there are many manufactures that have a "heritage" model fan ... like casablanca, minka aire, concord and emerson ... even Kmart sells a fan called Heritage (not a bad fan) ... of the above, casablanca has a high end model called "heritage" and that name is likely the domanant brand .. if you can find a model number then it can be isolated better ... .
    here is info on that one
    Casablanca Heritage Ceiling Fan
    http://www.carolinarustica.com/product.asp?pn=CB-C19624F&sid=BECOME&utm_source=Become&utm_medium=cse&utm_campaign=MerchantAdv
    Apr 15, 2010 | Vacuums
    Casablance fan repair
    Hi Billsboy,
    You can get replacements I believe. Call 979-553-3260 and talk to Gulffans Ceiling Fan parts. I know they have lots of Casablanca parts.
    Nov 03, 2007 | Casablanca Fan 3245T Ceiling
    Dryers Logo
    37 people viewed this question
    Top Dryers Experts
