Question about Admiral Washing Machines
Admiral model LNC6762b71 Washing Machine. Tub spins out of balance, even when empty, (w/o clothes or water). Even empty it will walk (slowly). Any Ideas will help, thanks, Karen in Cali.
  • 11 Answers
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
  • 38 Answers
SOURCE: Admiral washing machine MOdel AAV7000AWW On any spin will not drain 1st time through
is this machine induction motor or carbon brush if it is the inductin you need to be looking at the capacitor and if it is carbon brush then change them you will find them mounted each side of the motor and the capacitor will be @ the top under the lid near the pressure switch good luck
Posted on Jul 24, 2007
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
SOURCE: spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Posted on Aug 01, 2010
Admiral model lnc6762b71 tub dosen't center itself
Check balance springs at the bottom of the tub/drum. To gain access and remove front panel insert a knife or thin blade approx. 4" in the from each side in between the front seam on the front panel, this will release the lid clips, lift and hinge back the lid panel, remove the two screws securing the front panel and remove, there are 6-8 springs at the bottom, check all are intact.
Also check drum is rotating at full speed, if not check and replace drive belt below the machine, tilt machine back to gain access, flip belt off the pulleys and replace same way.
Nov 30, 2013 | Admiral Washing Machines
The tub will not stay balanced when it spins. Even with just water and no clothes.
You have lost a spring or springs that keep tub in place or the bearing is going out-is this a top load? cheers Denny
Oct 16, 2013 | Admiral Washing Machines
My maytag washer shake a end of rinse cycle.
After the rinse cycle, the washer rapidly spins the tub to get as much water out of the clothes as it can. It works basically the same way as a salad spinner. If the weight of the clothes in the washer is not balanced, the washer will shake and maybe even jump around during the spin cycle. This is pretty normal. If all of your jeans end up on one side, and your t-shirts on the other, the jeans will hold more water, their side of the tub will be heavier, and the washer will shake a lot during the spin cycle.
If the washer is shaking too much, open it after the rinse cycle (wait for the tub to stop before reaching in) and spread the clothes out evenly in the tub. Try to balance the weight. Then close the lid/door and let it continue spinning.
Mar 05, 2011 | Maytag Washing Machines
Spins out of balance even emty
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Admiral washer
Guess you need to change the ,it links motor to the transmission.
OR
There aren't enough clothes in the machine to keep the tub balanced. Wash bigger loads or lift the lid when the banging starts and re-space the clothes evenly around the tub .
Thanks for contacting fixya.com
Nov 10, 2009 | Washing Machines
Washer tub bangs when in spin cycle
There is not a repair guide , sounds like a spring may have broke or came loose inside on the frame take the front panel off to check for loose parts.
it may just be an off balanced load as well.
Phil
Apr 15, 2009 | Admiral AAV7000A
Admiral Top Load Washer Model LNC6762B71 overflowed
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Feb 28, 2009 | Admiral AW22 Top Load Washer
Admiral clothes washing machine AAV7000AW
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Huuum
Sep 19, 2008 | Admiral AAV7000A
Admiral Washer Model#LNC6762B71
if water leaks in the tub your water valve need to replace. and thelower bearing. i can let you know how much the parts are.and valve is not hard to replace but bearing is
Feb 18, 2008 | Kenmore 23822 Top Load Washer
Jul 24, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
