Question about Craftsman Garden
How to properly reinstall the throttle lockout spring for a craftsman trimmer model #358792010
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
Dolfoff
  • 148 Answers
SOURCE: need to install new lever trigger lockout but
Navigate to your exact model using Echo's public website.
Click the "WEB-PLUS PARTSEARCH" link at the bottom right of their homepage.
Posted on Sep 26, 2009
  • 41 Answers
SOURCE: Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Posted on Apr 14, 2010
  • 8 Answers
SOURCE: 32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Posted on Apr 27, 2010
rycgl
  • 1545 Answers
SOURCE: 325 X-L trimmer throttle doe not operate.
There should be a small recessed area off to one side inside the handle for the routing of the throttle cable...Look closely. The spring that controls the return on the trigger isn't too complicated either. It has to be held in place somehere on the throttle handle also and may have to be preloaded so there is tension on it when you install it..Look around closely in the area in the handle RIGHT above the trigger.
Posted on Jul 12, 2010
My 29cc 4 cycle craftsman gas trimmer loses power when I increase the throttle
While Holding the Engine at Full Throttle, Adjust the High Air Mixture Screw In Until the Engine Revs Properly.
Jul 01, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
I am looking for a part for Craftsman trimmer model # 358.796121. I need the pulley with the started recoil spring and string.
Go to www.searspartsdirect.com and put in your model info and they will provide you with a download or this will take you directly to the model with diagrams that you need:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358.796121/0247/1503820?pathTaken=
They sell parts on this site or you can probably order them online and/or go to their outlet and pick them up.
Please vote on this solution.
Sep 06, 2010 | Craftsman 25cc Gas Line Trimmer
How to I change the spring for the start-cord on a Craftsman Sim-pul weed wacker? p/n 530-059225
A bit of disassembly will be required for you to reach the point where you can access the starter/recoil unit. If you already have done so, it will be evident that you have to take the unit out, remove the old spring, install the new spring (paying special attention to the orientation of it in the pulley hub) and reinstall. Torx fasteners hold most all of the parts on this machine. If you take your time and don't rush it, it is not too bad. Check this site with your Make and model # for parts diagrams and breakdowns.
www.searspartsdirect.com or go to
http://www.ereplacementparts.com/ if you like.
Aug 16, 2010 | Craftsman 25cc Gas Line Trimmer
Jul 11, 2010 | Husqvarna Forest & Garden 125c 17"...
The pull string wont go back in on the weedeater
Likely the recoil spring has broken (often the end) or the plastic recoil winding in which the spring sets in has broken or worn to the point in which the spring will no longer seat properly. Complete removal is necessary to determine the problem.
May 27, 2010 | Craftsman 25cc Gas Line Trimmer
Need to install new lever trigger lockout but can't figure out how to install spring on echo trimmer srm 210
Sep 17, 2009 | Echo Garden
Garden Logo
43 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
