Question about Panasonic Lands Phones
Changed bell services to get better $ lost mssg going 2 base of panasonic I went back 2 original services & still only get mssg if I check on handset, my base doesnt light up & doesnt record...why
snakehead
  • 1074 Answers
SOURCE: Base won't charge handset
the base of your handset needs to be repair take it to a tech
Posted on Apr 04, 2007
PyroPCMan
  • 405 Answers
SOURCE: Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Posted on Mar 12, 2008
  • 3 Answers
SOURCE: Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Posted on Aug 13, 2008
  • 3 Answers
SOURCE: tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Posted on Nov 01, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
How to register 2 Bell Cordless handsets on 2 bases?
Multiple handsets registered to one base works well.
The extra base can be used as a remote charging
dock without registering a handset.
Trying to register a handset to two bases is neither
possible nor useful.
OTOH, the specific model number was
not given. While I have never heard of
registering a handset to more than one base,
nor made it happen by accident, maybe we
all do "...learn something new everyday...".
What is the specific model number, and the
date of manufacture ? Thanks! a r t
May 17, 2016 | Bell Lands Phones
How do I unblock a phone number
You can find the procedure in the programming section of the manual. Look for "Viewing/editing/erasing call block numbers" The Panasonic KX-TGEA20 model number crosses to the additional handsets for your cordless phone, but these handsets are compatible with the TGEA-21X through the -27X series base units. If the [MENU] # code sequence is different you will have to share your exact model number.
The Quick -n- Dir(ect) answer is:
    1.[MENU] #-2-1-7
    2.<Navigator key "up/down" arrows> to "Block a single number" ? [SELECT]
    3.<Navigator key up/down arrows> to highlight/select the desired entry.
    This should offer you the choice to edit or erase, so choose...
    4.[ERASE] ? <Navigator key up/down arrow> to "Yes" to confirm your action? [SELECT]? [OFF] The number should no longer be on the "Blocked" list if you go back in and start from step 1 (above).
    If you have lost your original manual you can get a replacement from the Panasonic FTP site here:
    ftp://ftp.panasonic.com/telephone/om/kx-tge210_mul_om.pdf
    V/R,
    Veg
    If a train station is where the train stops, what happens at my workstation?
    ~Author Unknown
May 05, 2016 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
KX-TGA660 handsets - 3 of 5 wouldn't ring (no sound)
sounds like who ever installed your service was an amateur, all points should be gone over by a senior tech, piece by piece!!
Nov 14, 2013 | Panasonic Lands Phones
I am unable to set handset to work with the base. Its panasonic KX-TG5933Al
Registering a handset
Important:
If you accidentally assign another
handset's extension number to the base
unit, the originally assigned handset
stops functioning. Confirm the extension
number of the handset by placing it on
the base unit or charger. Lift the handset
from the charger before registering.
1 Handset:
{MENU} i {0}{0}
2 Base unit:
Press {SELECT} until the desired
extension number (H1, H2, H3, or
H4) is displayed on the base unit, then
press and hold {CALL} until the
LH4 can be used if you have 4
handsets.
LAfter the CHARGE indicator starts
flashing, the rest of the procedure
must be completed within 1 minute.
3 Handset:
Press {OK}, then wait until the handset
beeps.
For futher information, see the phone manual at: http://dl.owneriq.net/3/3cd5d5a0-865d-4a28-8a1f-91f144108d9d.pdf
Mar 22, 2011 | Panasonic Computers & Internet
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Adding handset to Panasonic KX-TGA542M phone. ? how to ?
Oct 27, 2008 | Panasonic KX-TG5422M Cordless Phone
Answering machine replay is garbled
Your handset battery will have no effect on the answering machine audio, providing your regular audio is fine (its fine when you make a phone call right?), I will assume yes. I have seen this problem in these models, and your problem lies in your base station, and the only fix you can attempt is to go into base programming and delete as much as you can out of the memory, greetings, old messages, etc.. Power down, then power back up again. Call in and leave a message. See if it sounds better through the handset or the speaker on the base when you play it back. If its garbled both ways (reviewing through the handset or on the speaker base) , then your problem is in your base memory. If it is just garbled on your handset, then it may be a radio module problem with the base, either way it probably needs to go in for repair. I don't know if Panasonic still repairs that model, but if you google Panasonic cordless telephone repair, you will find someone. Good Luck, CG
Jan 11, 2008 | Panasonic KX TC1731 Cordless Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Lands Phones Logo
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
