I have a dishwasher, and when I turn the machine on, it starts beeping and blinks in the 1st and 2nd light. She is a schaub lorenz
SOURCE: i have a cda mx194
MX194 Dishwasher.
Switch off and unplug before doing anything. .
First three lights are flashing on top and it will not stop making stupid noises.
Remove plastic panels at front of machine under door, see if there is water inside.
If there is ... something is leaking. If it is a slow leak - solution is to dry up excess water in tray with paper towels or whatever comes to hand. You will need to find the leak somehow - salt container is usual suspect.
There is a microswitch attached to a float on the left hand side inside a white plastic cover. Water at the base of this activates the switch and disables machine. Mine has not leaked since trying this fix and machine is running well 2 months down the line. Better 10 minutes with paper towels than 2 hours of expensive plumbers.
Posted on Oct 29, 2008
emissionwiz
  • 78257 Answers
SOURCE: hard shift and blinking overdrive
The blinking overdrive button is telling u that a serious fault has occurred in the electronic controls or a mechanical fault such as excess slippage is occurring.
Posted on Nov 06, 2008
SOURCE: Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Posted on Sep 06, 2009
SOURCE: IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Posted on Nov 01, 2009
SOURCE: HOTPOINT BF1620 1ST AND 2ND FLASHING LIGHTS
disconnect from mains take off water pump from under the washer and bench test (apply 240v to the contacts). If the pump turns and is OK refit it. |The next thing to do is replace the control panel behind the front door. the part you need is TIMER BIT100.1 'S5' ROHS + N1045048 and can cost from £37 - £90 try amazon. fit and fix. |The control panel provides 240v to the pump, hence why you should replace it because yours isn't possibly?. do continuity checks on the cabling.
Posted on Jun 12, 2010
Why my Schaub Lorenz tv the last six months keeps starting up at maximum volume every time i turn it on no matter what the volume level was the last time the tv was turned off ?
Hi, Dimitris,
The memory chip in the main board of your TV seems to have gone bad. Please see if someone can replace it, or the main board has to be changed.
Good Luck.
May 04, 2016 | Televison & Video
Lcd schaub lorenz
E21 Code
Difficulties in draining
Drain hose kinked/blocked/incorrectly positioned; drain filter
blocked/dirty; drain pump faulty; wiring faulty; PCB faulty; current
leakage from heating element to ground.
Cycle paused. Start
May 06, 2014 | Whirlpool Washing Machines
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
I have lost the manual for dax ne -190e universal tv remote
i have the same problem & the same DAX remote control. and i can't find anything. It's like this DAX xompany does not exist!!!
Dec 30, 2012 | Televison & Video
The machine was about to start the spin cycle when it started to beep and two lights came on. When I turn the power on and off at the switch it just starts beeping again and the only three lights are on.
Hi just read your posting.Now when the machine beeps a series of lights will light up.They will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine is beeping.Is it the 2nd and 4th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Fisher and Paykel IWL12 Top Load Washer
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
