Question about Refrigerators
The refrigeration works fine for a few months and at a random interval will stop working. The ice melts and everything else gets warm. When unplugged then plugged back in, it works fine.
    Scholar:
  • 117 Answers
What is probably happening is you have ice buildup on your condensor(usaully located behind a panel inside freezer compartment) what happens is ice buildup over time will cause the condensor to stop cooling efficiently.One solution is to unplug frig and let ice melt off condensor, which you should do anyway unless it is a frost free model ,in which case you have a defrost problem. If this is the problem, you should check out the solution in one of my earlier threads posted 9/23 Hope this helps.
Posted on Jul 25, 2009
Our refrigerator is 2 years old a few months ago the back wall of the freezer was covered in ice and everything had melted. i took everything out melted the ice off the wall of the freezer and it started...
your defrost heater behind this wall isnt working to defrost the unit,a block of ice cant pass cold air,its either the heating element or the defrost thermostat or the main board in the rear area of the unit
Sep 13, 2010 | GE Refrigerators
The fridge will operate fine for about 2 or 3 days and then the inside will get warm and melt all the ice. I will unplug the unit for a few days plug it back in and it will operate fine for a few days and...
Sounds to me like you have a bad defrost timer. As the freezer is working correctly, it is building ice on the evaporator. It sounds like it does not go into defrost, thus freezing up the evap coil, and stopping the evap from cooling the surrounding air. Hope this helps
Jul 23, 2010 | Frigidaire Refrigerators
My fridge stopped cooling and freezing 4 days ago.I hear fans inside running and it just blows slightly cool air against the ice maker.The compressor is HOT and the main fan for the condensor doesn't seem...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 12, 2010 | Frigidaire FRS26R4A Side by Side...
My refrigerator is not cooling the freezer works
We have this refrigerator and what you described is a chronic problem. (I hate this refrigerator!) Our repairman got tired of hearing from us so often and told us how to fix it ourselves! Take everything out of the freezer side and unplug it. Remove the white back part inside the freezer part. There are 2 screws at the top. The inside will be full of ice. Melt the ice with warm water. It makes a huge mess so get lots of towels. Once all the ice is melted you can put everything back and plug it in. It may take a day for it to get really cool again. My long term advice is to get a new refrigerator...
Jan 05, 2010 | GE Refrigerators
Samsung fridge RS2630, icing up on freezer and fridge not cooling
Could be the defrost element. If it does not work and melt the ice off of the evaporator, icing will continue and serve as an insulator. Freezer and refrigerator temps will suffer.
If you unplug the unit and let it defrost for a day and plug back in it will work fine till it freezes up again.
Jun 25, 2017 | Samsung RS2630WW Side by Side Refrigerator
GE- GTS22WC refrigerator. Both the refrigerator and the freezer stopped cooling, We put it in the basement thinking it was no good, and after a few months we plugged it back in and it worked ok for about...
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
Jun 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Maytag Rerigerator
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Jan 09, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
