Question about Sony Audio Players & Recorders
Please help with troubleshooting bose 50 lifestyle. No remote. Have Sony reciever. Is module ie subwoofer vital to optimal sound ?
  • 883 Answers
SOURCE: Bose Acoustimass 6 No Subwoofer sound
take it back for refund or exchange without delay. Too many times, there are cases of faulty factory assembly. Most likely a poorly connected wire inside sub, which fell off after a few booms.
Posted on Jun 17, 2007
SOURCE: Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Posted on Feb 05, 2008
SOURCE: remote control program codes
want to know the code for bose lifestyle5.
Posted on Jul 23, 2008
SOURCE: bose acoustimass 25 subwoofer has no power
Honestly speaking you should probably not work on this unit yourself: "There are no user serviceable parts inside"
Even if you are an accomplished Electrical Engineer Bose will not provide the required schematics to troubleshoot and repair this unit.
Are you still undaunted . . . then if the case is the original LS-25 series, there is a hidden catch at the end of the cover furthest from the input connectors that needs to be rotated (until a plastic tab is sticking out), which you can do with a flat bladed screw driver, and you also need to remove a few screws from the bay where all of the connectors reside. Remove the two knobs from the side of the cover. Then hit the case with your fist at the far end (plastic tab) and the cover should then pop off. You may have to hit it hard, with an upward motion.
Note there is not going to be much you can do to fix this beyond replacing the fuse. (Note that the fuse may be soldered in.) The bass amplifier is op-amp based with discrete class G output stage and the twiddler amps are monolithics with discrete class G circuitry shared between several channels.
The power transformer has a thermal fuse in it as well which is not replaceable. If you play the unit loudly for long periods of time and it is not adequately ventilated it is possible for the thermal fuse to open - if this is the case you will definitely need to send it in for service.
When plugged in there are hazardous voltages present on the top PC board where the power connector is located, whether or not the unit is turned on.
Power switching is via a triac controlled by whichever front end you have CD-5? 12V should be present on the mini plug (tip I think, but might be ring) when the music center is on.
There is also offset detection circuitry that will latch the unit off should any output have more than a volt or so of offset.
For more information see following web site:
http://www.diyaudio.com/forums/showthread/t-106135.html
Posted on Mar 01, 2009
rodseesqi
SOURCE: Harmony 900 to control Bose Lifestyle problem.
Press the system button on the Lifestyle remote control. Move right to see a preview of the remote control. Press the down button to move into the submenus. Go down to IR Control. Select "on" System receives IR commands from another remote that has been taught to operate this system. Press exit and take a breath and try your Harmony remote. It should work. I had the same problem and this fixed it after hours of screwing around. Good Luck
Posted on Dec 23, 2009
Bose troubleshooting
my bose 50 remote says no response, bose had a look & said they couldn't replicate the fault, there's a lot of this issue about but what's the remedy
Jan 02, 2014 | Bose Lifestyle 20/25/30/40/50-50 Series...
Lifestyle 50 not responding
Reconnect the Bose link connection at the Multi room interface and at the Acoustimass Module.If this doesn't help,change the remote control batteries.If the it still display "no response",it means either the interface or remote is bad
Jul 28, 2013 | Bose Lifestyle 40/50 Music Center Used...
Hello, We have Bose Lifestyle 12 system. It has been working great until now for 10 years. We moved homes locally with in town. Now when I tried to hook up my system, there is no sound coming out of the...
Please check if the AC cord of Acoustimass module has a good connection to AC outlet, also check all the connections specially the cable that goes to the system control unit jack, for your reference in the link below you can see and download the manual of your Bose system:
http://www.bose.co.uk/GB/en/images/Lifestyle%2012%20Series%20II%20Home%20Theater%20System_tcm6-4071.pdf
Mar 04, 2011 | Bose Lifestyle 12 System
Bose lifestyle 5 keeps shutting off sound
KEEPS SHUTTING OFF SOUND AFTER ABOUT 1 TO 2 HOURS OF PLAYING. HAS POWER, EVERYTHING LIGHTS. I THINK THE PROBLEM IS SOMEWHERE INSIDE THE ACCOUSTIMAS MODULE OR THE SUBWOOFER.
Dec 13, 2010 | Bose LifeStyle 5 Series-III CD Shelf...
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Apr 05, 2009 | Bose Lifestyle 18 System
Bose Av38 Media center remote contro issue.
problems of conectivi betwen samsun and bose products many people whit same problem,
Mar 25, 2009 | Bose Lifestyle 38 System
HOW TO HOOK UP SUBWOOFER
sell your bose system and buy a real home theater surround sound system with a real subwoofer and not a Bose "Bass Module"! Problem Solved!
Dec 07, 2007 | Audio Players & Recorders
32 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
