Question about Bose Audio Players & Recorders
Unsure if my question was clear. - Lifestyle 50 Bose hm system troubleshooting. No remote. Connect via subwoofer and I think post said hd phone
Commented on having to turn on via subwoofer. NO PROB !!! JUST WANT ON !!! Thanks
SOURCE: Bose lifestyle 25 system and Panasonic Plasma Tv not working together
I posted the message as Tet Tet before. I can now tell you that I have resolved the problem. The issue is with the Panasonic 50Inch TV. Some people reported the same problem but only when the TV was up on the wall. It turns out that the problem lies with the metal discs which screw on at the back of the TV to enable you to hand the TV on the wall bracket. In my case I had excessive interference caused at the back of the TV (could be the fan). When I put the TV on the wall bracket the metal discs would be in contact with the wall bracket which in turn was acting as an antenna causing the iterference to the bose remote which operates at a frequency of 27.45MHz. You can solve the issue by adding some insulating tape around all the metal discs avoiding them to make contact with the wall bracket. If that fails Panasonic will swap your TV for another one like they did with me. I can now enjoy my Bose System with the 50 inch Panasonic TV. It took me three months but managed to get a solution. I hope this helps. For further info you can mail me at rizzocarlo@hotmail.com. These discs should be made of metal because they are perforating the metal screen at the back of the TV. Panasonic please change this design.
Posted on Jan 16, 2008
SOURCE: Remote Code
codes for bose123
Posted on Feb 03, 2008
SOURCE: How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
Posted on Feb 01, 2009
SOURCE: Code for sky + remote to operate bose cinemate volume via the sky remote ?
1356 something like that ;)
Posted on Sep 25, 2009
rodseesqi
SOURCE: Harmony 900 to control Bose Lifestyle problem.
Press the system button on the Lifestyle remote control. Move right to see a preview of the remote control. Press the down button to move into the submenus. Go down to IR Control. Select "on" System receives IR commands from another remote that has been taught to operate this system. Press exit and take a breath and try your Harmony remote. It should work. I had the same problem and this fixed it after hours of screwing around. Good Luck
Posted on Dec 23, 2009
Bose troubleshooting
my bose 50 remote says no response, bose had a look & said they couldn't replicate the fault, there's a lot of this issue about but what's the remedy
Jan 02, 2014 | Bose Lifestyle 20/25/30/40/50-50 Series...
Bose lifestyle 50 "no response"
You can find a bose M1 on amazon already refurbished
Apr 13, 2013 | Bose LifeStyle 50 System
BOSE LIFESTYLE 50 REMOTE CONTROL NOT WORKING
FOR THE BOSE LIFESTYLE 50 SYSTEM (Model P1 - Personal Music Center remote)
You can re-calibrate the remote first by following the steps below:
1. press and hold down on the display screen in the top middle area of the remote
2. After a few seconds the word CAL will appear in the middle and the word SOURCE will appear in the top left area of the remote.
3. Press the SOURCE button.
4. The word KEYPAD will appear in the top right area of the remote
5. Press the KEYPAD button and a small circle will appear in the bottom right of the remote.
6. Press the Circle
This should've recalibrated the remote.
If you need to relink the remote to the system, HOLD down the mute button while having the remote as close as possible to the unit. You will hear a beep . Release the button, after a pause , you will hear the remote beep twice.
This re-links the remote to your system
If the backlight is not working, your options are
1. Spend $349 and get a new one from Bose Or
2.Spend $220 and get a used one on E-bayOR
3. Use your remote with the lights on so that you can see the display :-)...the cheapest way OR Invest in an LED Book light that you can clamp on the remote and use that for your light ($9.99)
Sep 10, 2012 | Bose LifeStyle 50 System
I have a Bose lifestyle 50 (from 1999) and just purchased a new Sony Bravia TV. How can I connect the TV to the Bose sound system?
hello!
unless your "Bose" has an optical or coaxial digital stream audio inputs, there is no way of connecting TVs audio output to your receiver(home theater). to by pass the TV itself, connect analog audio output off your cable or set top boxes. those, still have analog audio out. If you need to connect more audio sources, use TV as a video monitor, connect all the audio outs to your "Bose", instead. In case of terrestrial broadcast, you may need to obtain digital converter box and use it simultaneously with TV to get your audio out. Also, if you lack DVR, that box will allow you to use regular DVD recorder. It's not going to be HD quality, but better, than nothing. You can't feed HD video signal out of TV set.Only analog.
good luck,
Alex.
Feb 01, 2012 | Bose Audio Players & Recorders
Is it possible to plug an Ipod into this system?
Hi, it is possible. All you need to do is get a two to one RCA cable. (one side RCA that has two mouths stereo, and the other side will have a jack mouth that will go into the ipod.
Connect the RCA cable to the output of the bose lifestyle system and connect the jack to the input of the ipod(where you plug your ear phone in.).
After that, set the bose to AUX. and you can start playing songs in no time.
Take care.
May 19, 2010 | Bose LifeStyle 50 System
How do i get my Bose Lifestyle remote to control
call bose tech support and register your lifestyle system with them, they in turn will start sending you update CD's those CD's may include the new IR databases that would help you find the right code. the other alternative is to call VIaSat and find out what brand's IR codes they are using( and in the IR menu on the bose try that brand's codes) A lot of manufacturers will use the codes from Motorola(worth a shot) the alternative option is to program a universal remote to control your bose, and all your equipment (if your equipment is hidden in a closet, get an RF remote, I program these for my clients all the time (for their bose systems))
Sep 12, 2009 | Bose Lifestyle V30 Home Theater System -...
Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
Apr 21, 2009 | Bose Lifestyle 48 System
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
41 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
