I have dl4000. I have no idea where keys are. I know passcode . How do I get it open?
Why can't safe be locked?
With mine, Is handle slightly loose and hanging down? Try lifting handle to move dial.
Feb 09, 2016 | Amsec dl4000 electronic lock safe
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
Passcode
I don't know what passcode is and I don't know where to activat
Apr 25, 2013 | Kensington KeyFolio Pro 2 Universal...
I hav a amsec dl4000 safe and forgot the passcode and hav no idea where the 2 keys r. the batteries work tho, is there anyway for me to open it??
I knew someone who had a locking mailbox like that with keys when pass is forgotten or battery runs down, they could open with key. He registered it as directions said to do so you could order new keys, the old mailbox was also lockable and since owner died he had to throw it away as couldn't prove he wasn't thief. Maybe something there helps.
Sep 08, 2011 | Safe International Digital Electronic Safe...
My son has forgotten his pin for ipod and now is saying ipod is disabled. have no idea please help as it's his b'day tom and have a ipod dock for him.
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
Feb 27, 2011 | Apple iPod touch
I'm trying to connect my son's MAC to our wireless internet that uses a Siemens speedstream 4200 router. The mac keeps asking for a wpa password. I found a 10 digit *** password under settings but can't...
Deriving the WPA passphrase is supposed to be VERY HARD. This is why no one uses WEP anymore, deriving the key was possible.
How many wi-fi devices do you have? If you enumerate all of them, including levels, someone may have an idea, because all the working devices have to know the passphrase. For example, if one of them is a Windows device, well, the passcode is somewhere on the windows device so that the driver can get it and it is possible to reconstruct it, I am just not sure how. Someone might know or it might be possible to find the procedure with a web search.
But what I would do is just change the passcode and then reconfigure all the devices you own to use the new one. Then I would write the passcode on a piece of paper and tape it to the router. You mostly care about the passcode to stop over the air attacks, (from people sitting in your front yard) and if someone can physically get to the router, they are allowed to know the over-the-air encryption code.
Jan 10, 2010 | Gateway Wireless-B Router (wbr-100)
Bypass numeric passcode key for motorola h371
Usually the default passkey is 0000 when pairing devices through Bluetooth.
Apr 22, 2009 | Cell Phones
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Dec 09, 2008 | Safe International Digital Electronic Safe...
Passcode forgotten
the passcode it's asking is the wireless security that was setup on your router. it could be a wep or wpa.
in order to get it, you need to access the setup page of your router. for most routers, all you need to is open a web browser and enter the router's ip address.
i can't provide the exact steps since i don't know the exact model of your router.
you can try to ask the person who manages your router for the wireless key.
hope this'll help you but if not, provide me the exact brand and model of your router
ciao!
Jul 24, 2008 | Dell TrueMobile 2300 Wireless Router...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
