Audiosource AST-Sub 10 subwoofer. it blows the fuse when turn on.
I noticed that my subwoofer is not making any sound. i check the power light and it was off. i check the fuse and its blown. i replaced it with the extra fuse that company have enclosed. i turn it on, and it made a sound for a split second, then it was dead silence. i check the fuse, and it was blown. what could cause this problem? i am sure that there is a short circuit some where? is my speakers gone? i hate to replace this subwoofer it has a great design. thanks for your help.
  • 3 Answers
It sounds like your audio amplifer has a short (probably the out put transistors or module). This should not be an expensive epair.
To check your speaker you can use an ohm meter. First, pull of one of the two wires that connects at the speaker. You should read 4 to 8 Ohms. Also you will hear a little pop through the speaker as you touch the wire. You can also use a 9 volt battery in the same way.
Good Luck
Posted on Jul 25, 2009
I have a jl audio 12 w7-3 sub and it just stopped working and wont work anymore,what could it be?
Check your fuses on your amp power lead and amp or make sure your amp is turning on the should be a light somewhere amps can break more times then the sub. Check all your connections or check your amp and head unit settings most probably a fuse mine blow sometimes
Jul 26, 2014 | Car Audio & Video
Paradigm pdr80 no sound
If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
Dec 25, 2013 | Paradigm PDR 12 Speaker
My klipsch ten inch subwoofer is making a high pitch whinding sound when the sub is turned on
my fuse keeps poppin everytime i put a new one when i turn it on how can i fix dat?
Aug 01, 2012 | Klipsch Synergy Sub-10 Subwoofer Speaker
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
Jan 08, 2011 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Power Light, Pulsating Level Control, Blows Fuses
you may of caused a short in the connections or it got moisture why in storge if so the hole subwoofer is screwed
Jun 07, 2009 | Infinity BASSLINK Car Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Klipsch ksw subwoofer wont power on
The power supply switching transistors are likely fried. Dangerous high voltages involved. I would remove the plate and send it to Klipsch for repair.
Jan 16, 2009 | Gem Sound SUB-650M Speaker
Fuse keeps blowing?
The fuse is a protective device. Fuses dont blow unless the amp ( in your case ) is drawing too much current. DO NOT put a bigger fuse in. Obviously, there is a problem with the amplifier inside the sub. If the sub is under warranty, send it in for repair to an authorized warranty depot. If not it's not under warranty, then take it to the authorized warranty depot anyway. Why ? because they will have the schematics ( electrical diagrams ) to troubleshoot the unit quickly and it may be a common problem. If it is a common problem, the factory may have released a modification and possibly it could be covered under warranty under a factory 'goodwill' program. Good luck. Rob
Mar 03, 2008 | Energry Speakers Energy Speakers S8.3...
Proficient Subwoofer S12 - No Power
Check the fuse which tends to blow frequently.
Oct 29, 2006 | Proficient S12 Subwoofer
353 people viewed this question
 Grubhead
Grubhead
