2 questions: 1. in the manual it states for fan only remember to open the vent and then when going back to A/C close vent. No place in the book does it show where the vent is. can you help me.
2. when I put the air conditioner into Auto mode and then hit the Temp Sensor on the remote the green light is supposed to flash. Mine turns on for about 3 seconds and then goes away, I have had the temp set at 70 and there are times that the temp gets up to 75 and I have to hit the temp sensor twice to get cooling to work, am I doing something wrong. My unit is a WWK05CR71N Window unit.
emissionwiz
  • 79847 Answers
SOURCE: cooling fan not working
The fans only run when the engine reaches approxminatly 235 degrees F. on the guage that is near the end of scale just before guage show "HOT" I don't think you have a problem, allot of folks out there don't know about this.
Posted on Aug 22, 2008
  • 659 Answers
SOURCE: How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Posted on Apr 02, 2009
  • 3197 Answers
SOURCE: Door won't close, blinks 10 times, sensor light yellow
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem or the wiring to them. Nothing else causes this symptom.
Posted on Sep 14, 2009
  • 3197 Answers
SOURCE: Have a Craftsman 1/2hp garage
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. If the transmitting sensor light is blinking it is bad.
Posted on Nov 22, 2010
  • 5370 Answers
SOURCE: My Fujitsu (AST9LSACW ) timer
Yes two flashes is indication of temp control setting problem.But still check this too:--- This are other reasons of poor cooling:-- ? Is the Air Filter dirty? ? Air the air conditioner's intake grille or outlet port blocked? ? Did you adjust the room temperature settings (thermostat) correctly? ? Is there a window or door open? ? In the case of Cooling operation, is a window allowing bright sunlight to enter? (Close the curtains.) ? In the case of Cooling operation, are there heating apparatus and computers inside the room, or are there too many people in the room? ---------------
? The air conditioner power has been interrupted by a power failure. The air conditioner will then restart automatically in its previous mode when the power is restored. ? Operated by setting before the power failure. ? If a power failure occurs during TIMER operation, the timer will be reset and the unit will begin (or stop) operation at the new time setting. In the event that this (kind of timer fault occurs the TIMER Indicator Lamp will flash . ? Use of other electrical appliances (electric shaver, etc.) or nearby use of a wireless radio transmitter may cause the air conditioner to malfunction. In this event, temporarily disconnect the Power Supply Plug, reconnect it, and then use the Remote Control Unit to resume operation. ----------------- Also if your require user manual for your Fujitsu unit.Please click on the link below:-- http://www.fujitsugeneral.co.nz/scripts/get-manual.pl?manual_id=40 ------------ This should help.Thanks.Helpmech.
Posted on Jan 20, 2011
WHY DOES TOP ICEMAKER FAN KEEP FREEZING
The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Apr 08, 2015 | Refrigerators
Why does my ice maker line keep freezing up? Replace the water valve about 5 times already and now the fan is making a loud noise unless I turn the temp to 42.
you have a defrost issue?
Fridge freezing up- and no fan or air circulation:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
Apr 06, 2015 | Refrigerators
Freezer section is making a fan noise. Model RS261MDWP
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
Feb 21, 2015 | Refrigerators
Getting an Er code while the refrigerator is warm. Freezer is cold. No fan blowing that I can hear.
Feb 14, 2015 | Kenmore Elite 22 cu. ft. Bottom-Freezer...
My refrigerator freezer keeps freezing up
Sep 10, 2014 | GE Refrigerators
Managemylife
Aug 25, 2014 | Kenmore Refrigerators
Kenmore refrigerator freezing 106.56534400
Aug 17, 2014 | Kenmore Refrigerators
Freezer keeps frosting up
Jul 14, 2014 | Samsung RB2155 Bottom Freezer Refrigerator
Ice freezing in vent
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required
Jul 06, 2014 | Samsung RF266ABPN Bottom Freezer...
Samsung rf265abwp ice buildup in refrigerator section inside back panel?
Jul 01, 2014 | Samsung RF265AA Bottom Freezer French Door...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
