Question about Cooktops
Where can I get a vitralux hob manual - Cooktops
Residual indicators & right hot plates don't work!
LOL like the way you put that about FAULTY ELECTRICIAN . and that would be my guess also .
Feb 11, 2016 | Cooktops
Hob light up.
I take it the two fuses you mention were the house fusebox and the fuse in the outlet in your kitchen? If you know the mains is getting to the hob and nothing at all is lighting up on the panel then this sounds like a job for the professionals. I can't find any mention of a reset button or user acessable fuse in the manual. The only thing left to do is check the main wire connection underneath the hob - if it is accessable. (switch off at the wall first!) Assuming you are in the UK Service force telephone number is 08705 929 929 Hope this helps.
Sep 29, 2007 | AEG 23 in. 67600KF-N Electric Cooktop
Cda gas hob Pilot light not sparking to light hob, can use a match to light burners no problem.
IS THE POWER TO THE HOB ON ?
IF SO IS THE FUSE OK ?
IS THE PLUG WIRED CORRECTLY ?
TRY THESE FIRST, IF NO JOY YOU CAN DOWNLOAD YOUR PRODUCT GUIDE FROM CDA ON LINE
Dec 27, 2013 | CDA 4X4SS Cooktop
USER MANUAL FOR SAMSUNG CERAMIC HOB C61R2AEE
Samsung has the manual you want is the 1.75 MB PDF at the bottom of the list here: http://www.samsung.com/uk/support/model/C61R2AEE/XEU-downloads . If this second link doesn't work, follow the directions below to reach this page.
Samsung has the User's Guide for the oven on the Support tab, see http://www.samsung.com/uk/consumer/home-appliances/cooker-hobs/ceramic/C61R2AEE/XEU . The support tab is on the right. The manual for the cooking hob can be accessed from the Need More Downloads link below the Download button.
I hope this helps.
Jul 06, 2012 | Cooktops
I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Feb 05, 2010 | Cooktops
Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Dec 26, 2009 | Cooktops
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
May 30, 2008 | Bosch 24 in. PIE675T01E Electric Cooktop
Cooktops Logo
81 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
