My MSRM extender is now not showing a secure connection.
User manual harris msrm wifi extender
So get another manual at mfg web site.
Sep 21, 2017 | The Computers & Internet
Have an EDIMAX range extender. Extender showing connected to router with no problems. Tried connecting my tablet and mobile to range extender and both come up with "Authentication Problem".
Have an EDIMAX range extender. Extender showing connected to router with no problems. Tried connecting my tablet and mobile to range extender and both come up with "Authentication Problem" Wireless Mouse AmanStino ML11 2 4G Cordless Mouse with USB Nano Receiver...
Nov 29, 2016 | Tablets & eReaders
Having problems with SHARP smart television. "Authentication Problem" keeps showing
Check you wi fi router Note the security key for its security encryption either WPA or WEP on the 2.4 GHz network
How do you do that you go to another computer and go to Dos Prompt and type in ipconfig and press enter
Note the default gateway ip address and type this into an internet browser to log into the router Hopefully you will know the admin user name and password for the router. if you are lucky it will be the default settings for user name and password.
Your TV will need to have the WPA or WEP authenication set up to the key that that the Wi FI Router is set to.
Sep 22, 2016 | Sharp Computers & Internet
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
Gigabyte b49g wont link with wireless extender
first, Keep in mind that you bring the device into the same room as your wireless router.Use NETGEAR, Linksys Router.
second, Green LED on the extender is showing green to be able to get the optimum performance on your devices.
third, if not get it than just reset to factory defaults
then manually changed the security settings for your router .
Apr 14, 2014 | Gigabyte GN-B49G Router
Netgear extender WN2000RPT
These are a huge pain and I would recommend returning it and buying a Devolo dLan Wireless extender since they can self-configure. If you insist on using the device you have, try these steps:
1. Reset Primary Router to have NO SECURITY (you should be automatically disconnected). Don\'t just reset to factory defaults! If your ISP requires specific router configuration to connect, resetting would erase all of those settings. Simply open the router config site and remove Wireless Security. The best way to know is to Google your Router and Model for configuration instructions.
2. Reset Extender to Factory Defaults.
3. Plug Extender in (if not already done)
4. Connect the PC to the ROUTER (which should have NO security at this time)
5. Confirm that you have connection to the Internet, as well as any network devices.
6. If #5 failed;
6.a. Make sure the old wireless connection (manage connections) has been deleted.
6.b. Close all Network Configuration windows (don\'t know if this matters, but sometimes the refreshed list refused to update with new config settings without this step).
6.b. Scan for available wireless connections.
6.c. Keep doing 6.a and 6.b until the correct wireless connection is shown. In my case, I kept getting "Cielo Secured" instead of "Cielo Unsecured" (or vice versa).
6.d. When the list shows the correct connection and security setting, select it to connect to the router.
6.e. Return to Step #5
7. Now you\'re back to essentially where you were to start, sans security. Close all Internet Explorer pages.
8. Open Wireless Connections again, and disconnect from the Primary Router, and connect to the Extender. If your wireless connection list is showing conflicting Extender and Security information, follow Step #6 until it\'s correct.
9. Open Internet Explorer. You should automatically be thrown into the Extenders Auto Configuration wizard. Follow the Wizard instructions until it\'s finished. When it shows the security settings, make sure that it\'s set to NONE.
10. Once the wizard is done, and you\'ve clicked on the "finished connecting" button in the Extender config, make sure you save the Bookmark as suggested - you\'ll need that later when you add security. Now, check your wireless status.
Hopefully it will show "Internet", not the pesky "Limited Connectivity". Open the Network & Sharing screen to verify there is no dreaded Red "X" between your Extender and the Internet. It may take a few minutes for the Internet status to update.
11. If Step #10 failed, start from Step #1 again, making sure that each device has been configured with NO SECURITY.
12. If Step #10 was successful, take a moment to step back and perform a 2 or 3 minute Chicken Dance in honor of the Computer Gods. .... Or, maybe not. wink.gif If nothing else, at this point you\'ve proven the Extender will work, even if unsecured.
13. Now, go through Steps 4 through 12. This time, though, configure the Router to the security level you wish.
14. Since we\'ve already configured the Extender once, use the Bookmark saved in Step #10 to re-open the Extender configuration site. Click on "Exit" when it opens if it wants to run the Wizard again. It may also guide you through updating the firmware if that\'s necessary. Let that finish before continuing.
15. MANUALLY configure the Extender by first selecting "Connect to Existing Network". If all things are set correctly, it will eventually ask you for the security key for your Router. Enter and continue.
16. This time, when it\'s done, it should have updated the configuration for BOTH devices using the Network Key you just entered. You should see an updated Extender security setting summary screen. Re-connect to the Extender (wait for the status to show Connected, then click on the button at the bottom. The Extender Status screen should be displayed.
17. Open the Network and Sharing screen to confirm there is still no Red "X" between your network and the Internet.
18. If Step #17 was successful, open Internet Explorer and confirm you can access the web. Yippee!!
19. If Step #17 failed, then the auto-config screwed up again. Click on "Wireless Settings", and manually configure the Extender to match what you set on the Router. Return to Step #17 to confirm that resolved the issue.
Fair warning, this will take a long time to accomplish. Netgear in my opinion is the worst brand on the market for wireless!
Nov 09, 2013 | Computers & Internet
Wifi
it might be the security that is messing it up... try to access users interface of the extender using your NOte... open a browser type in mywifiext.net/start.htm then change the wireless name of the extender to any name and then change the security to wep ... type in on the key 1 box any 10 digits numbers ONLY... and then apply
try to reconnect ur devices to the new extenders name the new password will be the 10 digits number you created. see if that helps... :)
Jun 12, 2013 | Audio Players & Recorders
I purchased a Netgear Universal Wifi Extender for my ipad, i've set it on on the ipad and it says its connected and evreything and the little correction mark comes up on the ipad showing connected. the...
Extender means it extends the existing Wifi or network. So the iPad now connects fine to the extender, but the extender needs to connect to the existing network either via Wifi or cable. You need to open from the iPad the admin page of the extender and find the connection details there to your existing network.
Nov 20, 2017 | NetGear Universal WiFi Range Extender...
Hawking Extender- Connected to WiFi but cannot access Internet
First think I always do is Reset Linksys Router and disconnect extender. Then turn off all security on router. Do soft reset on ipod. leave extender off and see if you can connect to the linksys. If you can then plug in extender (still with security off) then see if ipod connects to extender.
you might have to soft reset ipod again once you connect the extender.
if that works. reset security. Let me know how that goes.
Jan 01, 2010 | Hawking 802.11g Wireless-G Range Extender
Can't Connect to Netgear Range Extender Kit
-- you can connect the Xe102 to he wall plug where ur router is placed
-- And then reset it from the reset hole on the back of the Xe102
-- and after that connect the WGX102 to the other wall plug where u wanna get wireless access ..
-- And then reset it from the reset hole on the back of the WGX102 as well
-- And once u do that it will not ask for a security key .
-- It will show netgear unsecured
-- try to connect with it and u will be connected
Feb 14, 2009 | NetGear WGX102 54 Mbps Wall-Plugged...
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
