Question about Video Game Consoles & Games
My game has a blank screen! Please fix this for me! This is my favorite game
When i turn on ps3 all seems ok but when i click into game screen goes blank
Hello, It is normal for the screen to go blank when you hit the game icon. Because the that's the T.V adjusting to the HD-MI max settings. On the main menu, go to settings then video settings. Scroll down and you will see screen test, press that it will tell you what the maximum resolution for the tv you are using presently. You may need to change the resolution down and that will most likely fix this issue. It could also be the game disk, it it just this game that doesn't work? Or all? Also try replacing the HD-MI lead you are currently using, or at least try remove the lead and blow out and dust built up. If my suspicion's are correct, this will have resolved the issue. Any further questions please feel free to ask. Thanks for using fix ya.
Dec 09, 2010 | Sony Playstation 3 (PS3) Console
Blank screen
Try this,
turn the unit off, then back on this time holding in the power button until it beeps, a diagnostic screen will come up.
you need to restore this back to the factory so you need to select that option.
After that if you having issue it will need repair I suggest the fols at simply the best.
Please do be considerate and leave a positive feedbanc and ratings for you free answer today.
May 29, 2010 | Sony Playstation 3 (PS3) Console
After fifa 10 loads and you press to start game
The blank screen can be fixed it is normally down to the display chip getting too much heat, you can fix it yourself or you can send it in and Sony will fix it for you.
Dec 31, 2009 | Sony Playstation 3 (PS3) Console
Red ring of death
This sounds like the display chip is taking too much heat to fix it you need to stop the heat build up you can either do this yourself or send it back in and they will fix it for you.
Nov 28, 2009 | Microsoft Xbox 360 Console
Games and demos would freeze after about 10-30 min (or sometimes in less time) of gameplay. Now the Xbox 360 turns on but nothing but a blank tv screen and everybody's favorite red ring of death. What...
Go on, and it is one of the first FAQ's. It will direct you to fill out your info and MS will send you an empty box and a UPS label. Follow their directions, and you should have a new box in a couple of weeks for free.
Oct 24, 2009 | Microsoft Xbox 360 Console
Need for speed undercover blank screen.
it showing a blank disk how i istall this cd???!!!
Sep 23, 2009 | Electronic Arts Need For Speed: Undercover...
Now all i get is a blank screen
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like No Display Problme. You may check out the informative blog post at PS3 Repairs blog
Hope it helps to fix the problem...
Apr 03, 2009 | Sony Playstation 3 (PS3) Console
I put a game into the wii (blank screen)
it will be a recent game your trying to load probabaly with an out of date loader. newer games have something called an .002 problem where they can just crash due to disk errors.
install an up to date loader such as gamma loader and in config you can turn on "002 fix" and it will run.
it did it on mine with the new EA fitness game, and the above sorted it. mines softmodded running 3.2E
Mar 14, 2009 | Nintendo Wii Console
Nuvi 350 won't accept addresses -
I called garmin and they walked me through the solution - select the NA map version under settings and restart.
Oct 02, 2008 | Garmin nuvi 350 GPS Receiver
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
