Question about Measuring Tools & Sensors
Instructions on how to reset the outdoor temp setting after new battery was put in outside.
SOURCE: I have a skyscan atomic
This is a very common problem that is most frequently caused by the outdoor transmitter going bad. They are surprisingly delicate and don't like getting wet.
You can order replacement transmitters from http://skyscan.info/content/
They only cost $11 and that includes shipping and handling.
Posted on Feb 07, 2009
coupondeal
  • 76 Answers
SOURCE: need instructions on how to set time & temp
Tevion is part of Medion Australia Pty Ltd
Level 6, 35 Chandos Street St Leonards NSW 2065
Ph 1300 884 987 M-F 8.30am to 6.30pm (EST)
email: australia@medion.com
Try emailing them and see if they answer.
http://www.medionusa.com/
Posted on Jul 15, 2009
SOURCE: The outside temp sender won't work. We put new
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Posted on Aug 18, 2009
SOURCE: No visible outside temp. on SkyScan
Read some other posts on the net and they said to put in new batteries.........bingo!  That did it!
Posted on Aug 25, 2009
SD Tech
  • 14553 Answers
SOURCE: the outdoor temp on the LED read out says LL.L.
attaching photos here for your TV problem--they show the board and where the part is, if you attempt the repair I will tell you best way to get at it.
Cap is pretty generic part--almost any TV repair shop or Tv parts dealer will have it: .47 microfarad @ 200vdc (original part should have "0474 200 " marked on it and that is the value I indicated in plain english.
see photos and if you want to attempt I will tell you how to get the box out and do it.
Note board is seen removed from right side and pencil points to cap(it has been removed but the others around look similar)
just above this spot are two multi-pin plugs that have been removed.
Removing the light box will allow access without having to disconnect much.
Posted on Nov 16, 2011
My WS9620 does no show me the outside readings.batteries are new & the outside unit shows the temp. &the humidity
remove all batteries, bring the two units together and put the batteries in the base unit first, then the outdoor unit; they should sync within 2-3 minutes. Once they have exchanged temp and humidity once, you can separate them. Good luck.
May 02, 2017 | Measuring Tools & Sensors
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Nov 07, 2014 | Sharp Atomic Dual Alarm Clock Spc315...
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
Thermo clock RAR312 not picking up outdoor transmitter temperature. Replaced battery but still nothing.
take a paper clip and reset the reset button located in the battery compartment. Then, try each of the 3 channels until you get a reading in the outside temp field. Wait a good couple of minutes at each channel setting before determining the units are not pairing. Do this with the units side by side for signal acquisition, then once acquired, move the remote sensor outdoors. Hope this helps!
Sep 24, 2010 | Office Equipment & Supplies
Aug 23, 2009 | SkyScan 86709 Atomic Wall Clock
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Measuring Tools & Sensors Logo
131 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
