Question about Canon Office Equipment & Supplies
Canon ir ink match - Canon Office Equipment & Supplies
My CANON IR 2520 PRINTING VERY DARK SHEET AND SHOW ERROR CODE E000110 THANKS
Try removing ink cartridges and see if anything changes. If printer starts working fine, check which ink cartridge is bad by putting one at a time, or just change ink cartridges.
Jun 09, 2017 | Canon Office Equipment & Supplies
How to Clear Error- 000716-0010 in Canon IR2870 Copier?
E716 - There is an error in the communication with the pedestal.
After the presence of a pedestal has been detected, the communication fails to be normal for 5 sec.
1. Check the cable. Replace the DC controller
2. PCB. Replace the pedestal drive PCB.
http://www.smoothprinterservice.com/
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
Canon ir2870 e000732-0010
your problem might be faulty connection on your DIMM modules.
Take it out and clean the contact area with a brush, place it back and start the machine.
If this dose not solve your problem it means the Reader Controller PCB is faulty and needs replaced.
Oct 29, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Paper pick up
Be more specific you talk about Ink cartridge problem and also paper pickup. What is the problem???????
Sep 28, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Canon ir 3300 machine error code 0064, plz suggest
CLEAN THE DUST & WASTAGE INK ON TRANSFER CARONA IN MACHINE & RESTART IT .
Dec 20, 2010 | Canon imageRUNNER 400S Copier
Colored ink is smearing on the page when I print
Did you change the toner?Developer unit? When did it occured?
FIRST: the copier must be cleaned and vacumed, it may be that toner falls onto transfer section and that causes the problem, you may also have problem with yellow developing unit or drum or transfer cleaning blade.
Pls. rate
May 07, 2010 | Canon imageRUNNER iR C4080 Color Copier
Problem with my photocopier Canon IR 2000
copiers don't have ink open front door release lever for toner hopper make sure mag roller is covered thru the entire roller
Nov 24, 2008 | Office Equipment & Supplies
27 people viewed this question
old marine
old marine
