Question about Health & Beauty
How to use scales when new - Health & Beauty
Robinnair 34788
It's sound like problem from the relay board not from scale. Replace new relay board with old scale assy.
Thanks
Jun 27, 2014 | Robinair Cool Tech 34700Z Recovery,...
How to reset as scales are not weighing properly and new batteries have been inserted
These scales cannot be calibrated so i'm afraid that it's time for a new set. I think they were first manufactured in 2002 and they have a 10 year guarantee which meas you are out of luck. If you are in the UK, this site is a good place to start looking for another set of All Kitchen Scales
Jan 23, 2014 | Taylor Salter 1010 Stainless Steel...
New batteries but will not stay on
check for loose or shorted connection inside the scale.
Dec 05, 2013 | Taylor & Digital Scale Lithium Scale
Scales are getting a Err 1 message, installed new batteries, need to reset them some how. They will not zero themselves out
My scale was fine the other day. I weighed myself earlier in the day. I tried to weigh myself later in the day and the scale started reading ERR1. I called Taylor and they had me try to "reset" the scale twice. It did not work.
The steps for resetting it are:
Turn the scale over
Remove the batteries for at least 10 seconds
With the scale on it's side (even though you aren't supposed to put the scale on it's side, carefully insert the batteries and put the back on the scale
Slowly return the scale to a flat hard surface
Step on the scale after about 10 seconds of it being back in position
If the scale still jumps with crazy numbers and reads ERR1 try to reset the scale again being very careful when the scale is on it's side
If this does not correct the problem then the scale will need to be returned to the manufacturer, to the address on the label on the bottom of the scale
I was told you could put the scale in any box and ship it to them the cheapest way possible but be sure to keep the batteries with you
If you are still under the year warranty they will send you out a new scale in 4-6 weeks
I was not happy that my scale was purchased on 11/14/09 and it died on 02/12/10. Luckily I knew where my receipt was. I pulled it out and noticed 02/12/10 was the last date to make returns to Target for that transaction. I was able to go and return my scale to the store because it was in the 90-day window that I had purchased it.
I was told that the reason the scale was doing this was either an delayed electrical interference that may have occurred during. The only other reason I was given was an OVERLOAD. Well, I seriously doubt an overload was my issue. First of all I was the only person at home that day so nobody else stood on the scale. I had used it earlier in the day and it was accurate. I am 5'6" and 139 lbs. so I seriously doubt it was OVERLOAD unless someone isn't telling me something and I need to lose some serious weight.
Anyway, I hope this helps. I wasted a lot of time trying to figure it out that day. Now I have my new receipt and if this happens again I will go get my new scale just as I did this time. I thought a 4-6 week wait for a replacement scale was insane. Kudos to Target for taking the scale back without a box or instructions on the last day I was able to make a return.
Feb 09, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
I have a brand new scale that does not display anything even with new batteries, nd yes, the bateries are good and are installed correctly.
I have the same problem - brand new scale that does not display. New batteries are installed correctly. What is the solution?
Jan 13, 2010 | Jobar International Idea Works Wireless...
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Taylor 7530 scale wont turn on,i have new batteries
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
Dec 18, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Health & Beauty Logo
22 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
