Microsoft Flybook V5 Tablet PC Logo
Posted on Jul 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I was having a problem with my Flybook in that the screen would go dark but the computer was still on. It would work if I plugged in an external monitor. I finally went to the advanced portion of the video display and the troubleshooting tab and shut down all acceleration which seems to have fixed the problem but I tried to get back to the advanced area and now the button is disabled. I would like to get back in to set video acceleration levels so they are not completely off - how do I get back in now that the button is disabled?
Ekse
Level 3:
  • Microsoft Master 13,435 Answers
  • Posted on Jul 25, 2009
Ekse
Microsoft Master
Level 3:
Answers
13435
Questions
82
Helped
3983640
Points
38023
Uninstalling the drivers and then installing them again should return everything to default values.
so you can uninstall the software / drivers from start -> control panel -> uninstall programs / add or remove programs, find it from the list and uninstall. if noting related is on the listen then icnore this step and go forward to the next one.
on your desktop or on your start menu, right click on my computer or "computer" click on manage from the menu that comes up.
on the computer management window on the left side, click on device manager, then see on the right side, video adapters or display adapters or similiar, open it up from the + next to it, see your video adapter there? Right click on it and uninstall.
make sure all video adapters (most likely just one) are uninstalled, then restart the computer, it should start up in basic video settings and you may have to get the drivers for the video card from the makers website (I can look them up if you send me the brand and model of the laptop)
All the settings will return to normals and the hardware acceleration should be turned to full, and you should be able to adjust it again.
2answers
Kindle is "locked" in dark screen on the Contents page. I will probably have to replace it, but how do I save my books ?
it may work if you connect your kindle by cable to your computer
the computer will recognise as onther storage device open it see if you can locate your books slect and copy create a folder on your computer paste /save once you know it is saved reset your kindle
hope it works
2helpful
My flybook batteries are not charging. What can i do?
FLYBOOK EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Hi I have a flybook 3G and the internal battery is not charging, where can I source another internal batery???
Where are you exactly located? you can order battery directly to flybook company or you can contact at www.memega.com
I need the motherboard for dialogue v5w1bbha how do i get it to buy
This is something that can be taken care of. I got help by sending an email to: [email protected]
I hope this helps!
1helpful
2answers
HP Compaq 2710p: External monitor does not display anything
The display properties indicate the hardware is working, so it's likely just a setting.
On HP/Compaq models you will see a picture, usually on the F4 key that looks like a screen with two lines beside it.
You need to hold down the Fn key(bottom left) and then push the F4 key at the same time to cycle between LCD, external or both.
If it is a newer model, a menu will pop up when you do this asking if you want to duplicate the LCD on the external, switch to the external or extend the desktop onto the external. Select the appropriate setting or continue holding down Fn while pressing F4 to cycle between the settings to the one you want.
If you have re-installed the computer at some point with anything other than the factory recovery set this may not work and I will have to give you a longer set of instructions.
If this works please rate this as fixed, if not reply back and indicate what version of windows you're using and I will post the instructions for the "long" way.
Chris
Hp tablet pc has a blank screen
You're first step should be to plug an external monitor to it to make sure the video card still works. In all likelyhood, the video inverter (located behind the bezel for the screen) went bad and needs to be replaced, but it's good to know whether or not the computer itself is still putting out video
Laptop Screen Dull
Look a the screen real close, if you see a faint dark version of the image, this could be a backlight issue, otherwise a screen cable or a logic board issue. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, it's a pretty arduous repair that requires 1-2 hours for a trained person. It's feasible to do it yourself if you're tech savy, but you'll most likely have to google for guides that show you exactly how to replace the backlight step by step. Check on how to take the screen apart and make sure inverter is still connected properly. If so, you have a backlight issue. I work for Computer Repair NYC and i have to fix this problem a lot, it's so easy to break the lightbulb in the process.
Video Card problem?
Doesn't sound like a GPU as the external works . Could be screen or flex cable maybe ?
Top Microsoft Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
