Question about Lexmark Office Equipment & Supplies
I have a lexmark x8350 and i cleaned the inside. now i have alignment problems & ive noticed a spring hanging under the left side of the printhead tray. The part where it sits stationary
2 Suggested Answers
SOURCE: lexmark x8350
In the back of the printer is an access panel with one screw to hold it in place.
The outer side edges are held in place with it plastic tabs (which you can not see due to they are inside the printer. So carefully remove this panel without breaking the tabs. Look inside and you will see a ribbon connecting to a circuit board. This is probably loose or disconnected. The end of the ribbon is hard and not flexible. Push the end of this ribbon in the white plastic standoff slot. This ribbon sometimes comes loose when the top scanner cover is partially remove from the printer. I said, partially because if you needed to remove the top scanner completely, then this ribbon would need to be completely disconnected. You can also see, when the access panel is off, other wire connections connected to this circuit panel. Sometimes they also come loose or disconnect when the top scanner is partially remove. Connect them if they are loose or disconnected. I believe to solve your problem is the ribbon disconnected. Best wishes in solving your problem.
Posted on Oct 10, 2008
Printer is skipping random words at the beginning and end of sentences.
First, make sure that you're using genuine Lexmark cartridges. If not, replace the cartridges.
Second, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
Third, perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If the steps above doesn't help and you're using genuine Lexmark cartridges and provided that your printer is still under warranty, please contact our technical support team to have the printhead replaced.
If not, you can go to www.lexmark.com to purchase a printhead.
Nov 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
How to replace mirror motor assembly lexmark t632 or printhead
I would suggest you contact a certified Lexmark trained technician to replace the printhead or you may contact Lexmark Technical Support.
Oct 12, 2011 | Lexmark T632 Laser Printer
Printerhead error 933.00 what can I do to fix it??????
933 error is the high sycn failure on printhead you can strip printhead down and clean all mirrors whilst stripped try the mirror motor to see if it spins ok if not i am afraid its a new printhead. to get to printhead left and righ covers need removing take screw out of each side of top cover and remove carfully to get left cover off redrive has to be removed and screw top of frame undone and screw inside where toner is.
Sep 06, 2011 | Lexmark T644 Laser Printer
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
Lexmark C920 color print is faded on bottom of page
Quite possible something happened to the printheads.....especially the Magenta one. Might have been 'bumped' out of alignment. They might just need to be wiped clean with a toner cloth. They are usually right above the toner cartridges. Have you tried a color alignment adjustment in Config mode?
Mar 12, 2017 | Lexmark C920 Led Printer
Lexmark T644 left side of prints faded. New toner cartridge, transfer roller, Charge roller, left&right transfer roll arm, HVPS & laser unit. Same problem Please help
pull the toner cartridge out leave the bottom front cover open and bring down the top cover. with a flashlight check to make sure the charge roller is comming down straight if it comes down even. check to make sure the transfer roller has spring tension on the left side if the pring tension is present you will need to clean the flat leading edges of the mirror motor drive inside of the scanner located under the top cover.
Nov 04, 2009 | Lexmark T644 Laser Printer
Lexmark x8350 printer voice notification
hi try this...go to start- all programs-lexmark X8300- lexmark solution center ,
on the solution center page click on the last tab on the left hand side...u have an option for the voice notifications...
Feb 09, 2009 | Lexmark X8350 All-In-One InkJet Printer
Need to install Lexmark x 8350 on new computer don't have disc
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
you can get the drivers/software off the lexmark website.
i provided the link to start the search.
hope this helps.
Feb 02, 2009 | Lexmark X8350 All-In-One InkJet Printer
I refilled the ink cartridge in my Lexmark x8350 all in one printer and the cartridge won't align. I've cleaned the cartridge repeatedly. What do I do next?
If white lines are present in the alignment page, then try this, warm some bottled water on the stove or microwave untill it almost boils. Then pour the water about a quarter of an inch deep in a plastic clean cup, place the printhead section of the cartridge, (the part that the ink sprays out of), in the water and let set for about 5 to 10 minutes. When you remove the cartridge from the water, dab it several times on a lint free paper towel or an old cotton cloth, DO NOT RUB or touch the printhead with your fingers or anything else. Then using a cotton swab dampened in rubbing alcohol, clean the shiney electrical contacts on the cartridge and where they touch in the machine. If you still cant align, then probably its time to replace the cartridge. You can only refill so many times before the printing elements burn out with usage.
Hope this helps,
Printdoctor
Dec 04, 2008 | Lexmark X8350 All-In-One InkJet Printer
Lexmark x8350
Sep 28, 2008 | Lexmark X8350 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
