Question about Health & Beauty
How can I solve E10.11 problem with my scale
Programming soehnle volga
If battery replacement did not help, the scale may have failed.
Sep 19, 2016 | Soehnle 63691 Volga WhiteGrey Body Balance...
DO NOT PURCHASE WW BATHROOM SCALES BY CON AIR
pout this case directly to the manufacturer and you may get a warranty replacement set or a refund of the money
they do not know if consumers do not complain about their product
Oct 02, 2015 | Conair Health & Beauty
Error 2 . How can we solve this problem. Thank you, Margaret
I found this procedure which was given by Taran_2005. I just come to try him(it) on mine, that works.
"The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero's or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away."
Sep 10, 2011 | Terraillon FBC Alteo Family Body Control...
I step on the scale and nothing shows up
Please look for a lock that can be fixed- if this is new- so as the scale does not move while transporting. This is seems on many machines and look out for screws that hold the scale settings mechanism. removing them must solve the issue to restore the tray to act .
Feb 23, 2011 | Taylor & Digital Scale Lithium Scale
How do you calibrate the scales on A robinar 34800
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 (old typ machine 8787 without F1 botton on key pad) & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
Hope this will solve you.
May 19, 2010 | Robinair Cool Tech 34700Z Recovery,...
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
May 14, 2010 | Salter 2001 electronic kitchen scale
Hown to reset scale
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & enter (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press ENTER botton.now follow the on screen help text.Hope this will solve your problem.
Mar 26, 2010 | Robinair Cool Tech 34700Z Recovery,...
Where can I get a manual, after moving I can't find mine!
Troubleshooting Conair WW81 Weight Watchers Body Fat/Hydration ... Solve Your "Conair WW81 Weight Watchers Body Fat/Hydration Scale" Problem Now! ... Tanita Ultimate Scale 2001 - no user manual -how to set. ...
www.fixya.com/support/...conair_ww81...body.../solutions
Oct 05, 2009 | Conair WW81 Weight Watchers Body...
Health & Beauty Logo
23 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
