Question about In Microwave Ovens
My Firenzi oven SF904WH went dead on me, cant get it back, is there a thermal fuse in it that could have went?
4 Suggested Answers
SOURCE: Oven died while using convection feature
Thanks for the help !! It turned out to be the oven cavity TCO which is in the upper l/h corner under the grill.. I ordered the part which cost me $21.50 incl shipping.. It's not a big deal to change.. I'm just a little ticked off because I've only used this oven 3-4 times.. It was manufactured in July 2003 (I've had it in storage for two years untill my kitchen renovation was done).. If it's acting up now what else am I in store for ?? Well thanks again !!
AMT
Posted on Oct 23, 2007
Treefrog15
  • 127 Answers
SOURCE: Yesterday, my sharp carousel r-1460 went dead. I
If the 20A fuse is blowing, it is often the high voltage transformer or magnetron. If this is the case, and the microwave is not under warranty, replace it. Residential microwaves are generally considered disposable. Parts and labor are just too expensive. A magntron or transformer can cost more that half the cost of a new microwave.
Posted on Feb 25, 2010
  • 8909 Answers
SOURCE: Problem with the Bosch HME9760
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Posted on Jan 06, 2011
Microwave has no power the powe sourse works
Hi, your microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
If it goes dead for a while during or after cookingthen comes back on, the magnetron is probably overheating and causingthe magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should readopen, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Ifit goes dead or blows the breaker (or GFI) when you plug it in or open or closethe door, then there's a problem with a door switch or door switchmount.
If it's intermittent or random, it may be a badconnection, usually on the control board or a loose fuse holder, oreven an intermittent fuse.
You should do a continuity test onthe fuse while it's in the holder (with the microwave unplugged, ofcourse) then turn the fuse by hand or take it out and put it back in,then test it again.
If you remove the fuse, then press the meterleads against the ends, it can allow internal contact to be made andmake a bad fuse appear to be good.
Mar 27, 2011 | Maytag Appliances Over-the-Range Microwave...
Problem with the Bosch HME9760 / HME9750 800 Watts Microwave Oven Small pop when i went to open door, and now looks dead. 13amp main fuse all ok, so i assume its an internal thermal fuse or something...
Hope this helps.
Jan 06, 2011 | Bosch HME9760 Microwave Oven
Yesterday, my sharp carousel r-1460 went dead. I took apart the front keypad and replaced the 20amp fuse behind it. the microwave light and fan work.But, when I start microwave to cook something, pop! fuse...
Feb 24, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Unit dead Unit is dead - suspect blown fuse
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
The reason for this is that if you do not have any experience and training with microwaves, you can get a SEVERE shock, even if the oven is unplugged. THAT being said, if you still want to know where the fuse is get back to me. good luck.
ALSO, as you may know, a small microwave these days is under fifty bucks at walmart.
May 20, 2009 | Sharp R-1880LS 850 Watts Microwave Oven
Microwave went dead
Hi
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | Whirlpool MH7140XF Microwave Oven
Control panel went off and hence it stopped working
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Frigidaire / Whirlpool installation instructions here.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 26, 2008 | Frigidaire PLMV169DC Microwave Oven
No Lights just turned off
Chances are the magnetron overheated and the blew the thermal cutout (TCO or thermal fuse), thus protecting the magnetron.
Bacon has a fairly low moisture level and when can cause overheating if there's no water load in the oven.
That said, a microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing the fuse of a MCO160UW
A microwave can be dead for many reasons.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Jul 15, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave/convection oven simply lost power. not the outlet checked with hand mixer and worked find. is there a fuse that went out? how much to repair? thankx!
The fuse is usually located either between the door switches or on the floor of the oven behind the control panel.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We may have the service manual which we can upload for you. Please reply back with your brand and model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Sharp Microwave Ovens
Complete Shut-Down
I woulds first suspect a blown internal fuse or a thermal cutout on the magnetron in your case, but a microwave can be dead for many reasons.
If it goes dead for just a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power on again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 23, 2007 | GE Monogram ZE2160SF Convection /...
Microwave Ovens Logo
26 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
