Question about Food Mixers
I changed the motor of kw800 food mixer the speeds are not changing
mirran
  • 515 Answers
SOURCE: Blakeslee A717 speed control
where are you from, i have phone number to agents that still provide support for A700 series.
Posted on Jul 12, 2008
jmgldsmth
  • 2005 Answers
SOURCE: problem in speed mixing.i want to change the motor,where can i order to buy this thing. thank you..
www.easyapplianceparts.com/KitchenAid-Parts.htm
Posted on May 20, 2009
kel1guy2002
  • 3740 Answers
SOURCE: The mixer motor starts and stops, it will not
Here is how your speed control works:
Speed Control
The speed control of the mixer is attained through the use of a governor assembly mounted at the rear of the control plate assembly.
The electrical circuit is made and broken by the action of the fly ball governor revolving against the control plate.
When the switch lever is moved to an ON position, the position of the control plate with respect to the governor is changed by the action of the switch lever.
Thus, when the control plate is set close to the governor, a relatively low speed of the motor causes the governor to make or break the mixer’s electrical circuit through the control plate.
When the control plate is set farther away, a greater motor speed is required before the governor starts breaking the circuit.
The action of the governor is such that the speed of the motor will remain constant for a given setting of the control plate within certain loads.
After certain loads have been exceeded, the speed of the motor will drop to meet the torque requirements of the given load.
Speed is controlled by the governor and the control plate in conjunction with the phase control.
TRIAC RMS VOLTAGE
BOTH CONTACTS OPEN - 40 VOLTS
ONE CONTACT OPEN - 80 VOLTS
BOTH CONTACTS CLOSED - FULL VOLTAGE
NOTE: The triac regulates the power the motor sees depending on control board contacts.
A device called a triac is a part of the phase control circuit.
This device determines the amount of power the motor sees dependent upon the condition of the control board contacts.
If both contacts are open, about 40 volts RMS is applied to the motor and about 80 volts is applied when either contact is closed and the other is open.
When both contacts are closed, the triac is full on; consequently, full power is applied to the motor. In this way, the speed is controlled.
If the mixer motor begins to run too fast for a
particular speed setting, one or both contacts open, which cuts back on the voltage the motor sees, thus slowing it up.
If the motor operation becomes too slow, one or both contacts will close, applying the needed voltage to the motor to sufficiently increase motor speed.
This is always accomplished through the triac.
The control plate contacts control the triac, and in turn, controls the amount of power supplied to the motor.
The control Plate for your mixer is PN
W10119326
http://www.marbeck.com/mixers_kitchenaid_parts.html
If your not good with tools / meters or tedious repairs do NOT attempt this yourself.
The service manual for your mixer can be found here
http://www.f-ems.com/download/DownLoad.aspx?DocsID=082009012917
and is:
LIT4177310-C
Posted on Mar 14, 2010
  • 3 Answers
SOURCE: Hello, My mixer will not change speeds. IT looks
The phone number for Kitchen Aid Counter Top Appliances is
1-800-541-6390 8-8 EDT M-F and 12 - 5 p.m. Sat They should be able to give you a local authorized repair place.
Posted on Oct 22, 2010
vetteman3002
  • 2299 Answers
SOURCE: DSM800 (DeLonghi branded Kenwood mixer) - I need
Yes the KW800 Kenwood attachments will work.
Posted on Jan 07, 2011
KitchenAid Speeds are offset
Ideally you need to fix what's bent and that normally would involve splitting the cases to get at and repair or change the speed control lever. If you don't want to do that then removing the back cover and altering the adjustments and maybe bending the switch contacts may make it operate at both ends of the speed control.
Oct 04, 2017 | KitchenAid KSM150PS Artisan Series Stand...
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 | Food Mixers
At its lowest setting, our mixer spins at ever increasing speeds until it stops and then, will not work at any setting.
Your motor needs to be replaced. The speed setting should be able to be set from the start, and if it will not slow down or change speeds, the motor has been over-heated and will need to be replaced. The only quick fix for this is to bypass the speed setting, and change the brushes on the motor. If you do not know how to do this, ask a serviceman to change the brushes only. Brushes usually run about $30 to repair. Although, you will only have one speed.
Nov 16, 2010 | KitchenAid K45SS Classic Stand Mixer
The motor works fine and you can hear it engage as you change it from speed to speed but the the beaters do not turn
This sound like the worm gear has failed: http://kitchenaidmixerspares.co.uk/Home/tabid/36/p/Mixer-Part---Worm-Gear-and-Bracket-240309-2/ProductID/103/CategoryID/17/Default.aspx
You will need to take the mixer apart to confirm this.
Jan 23, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer running too fast.
Change the speed control board. Repair alot of these
Dec 24, 2009 | KitchenAid K45SS Classic Stand Mixer
The mixer rpm is too fast
No change available. The motor speed if fixed and the 3 speed transmission has fixed gear ratio's. Look at the new HL300 model. It has a stirr speed which is slower than first speed.
Does your mixer havea safety cage? If not, you will need to install one before too long , or the machine will not comply with current safety standards. Put the cost of the safety kit towards the HL300.
May 26, 2009 | Hobart D340-6007 Mixer
Sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
Nov 25, 2007 | Sunbeam 2485 MixMaster Series Hand Mixer
Food Mixers Logo
50 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
