Question about Garden
Can't engage forward on a slight grade with my walk behind Gravely 5660 self propelled tractor
SOURCE: 6.5 toro walk behind self propell b&s engine.
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
Posted on Aug 07, 2009
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
  • 486 Answers
SOURCE: craftsman self propelled walk behind lawn mower
Normally grass and debris are clogged under the belt/transmission cover, preventing the full engagement of the transmission cable/lever.
The cover is located on the topside, left front corner of the mower shell. Clean debris, try it again. If OK, re-install cover, If not, there is a cable adjustment (threaded portion with a nut on either side of a fastening arm) move the cable adjustment towards the rear, this will tighten the cable. Sometimes the cable assembly (includes the cable and the control box) needs to be replaced
Posted on Nov 08, 2009
SOURCE: Engine runs at full throttle.
Well I would, suspect, that some sort, of drive or clutch mechanism, that isn't transferring the Drive, to the Propelling wheels. You need to troubleshoot, that, see if a belt, or chain, maybe has come off or broken? If it is all intact, but it goes through a gear train, well that maybe faulty, broken.
Posted on Apr 14, 2010
  • 760 Answers
SOURCE: i have a john deere js63 walk behind and the self
See this link and follow directions for servicing drive belt. Scroll down to section for your JS63
Posted on Jul 26, 2010
Why isn't something engaging when accelerator pressed?
It would help to know more information about the mower in question. Walk behind push mower? walk behind self-propelled mower/ Riding lawn mower? Lawn tractor? Or goat...just The engine horse -power or cc's and make of the mower and engine. Anything happen before the problem or was it straight out of storage. Does the gas pedal feel normal? Could you be talking about the forward/ reverse pedal? These types don't engage by depressing them, they engage by releasing the pedal.
I'm going to guess you have a riding lawn mower or lawn tractor. The pedal for those types of mowers controls the transaxle ( rear wheels, transmission and differential basically). If the pedal move properly and it was working ok when it was stored, then check to see if you can push it with little effort. On most transaxles there is a disconnect rod to disengage the transaxle for towing the mower without damaging it. Pulled out for disengaged and in for engage. If that all checks out it could be very low on transmission fluid or the drive belt might be off or broken depending on which type you have. If it is low on fluid, you have a leak. Hope this helps.
Mar 11, 2016 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Husqvarna Model 5521BBC. variable speed, walk behind, self propelled. The mower start fine, goes into cutting gear, but when I try to use the "self-propel" feature, it does not engage. It's rear wheel...
yes it could sounds like the cable is out of adjustment remove cover to see if belt still mounted and how to engage selfpropepelld adjust cable accordanlly
Aug 23, 2013 | Husqvarna Garden
New tractor power loss on a grade, deos not develop full speed
Hello Joe
If you have an automatic or hydrostatic transmission then you have a lemon, which means once the oil heats up in your transmission it thins out and clutchs and swash plate have no grip on the drive system which is hydraulic pressure needed to hold on the shaft and axles this happens all inside the transmission you cant see it but you can tell when going up slight hills and when you have the blades engaged it crawls like a turtle get you warranty out Joe..... dont touch anything that may void your warranty..... just call service department they will send service man out to your home even after that keep a good eye on your tractor since its still under waranty for further problems.
Joe your 20 year old craftsman had a better built ****** by sears and you probably had a 6 speed or five speed even hydostatics were good too,they dont have much problems except belt slipping its an easy fix this new tractor u need service man right away.
Oct 08, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Troy bilt self propelled 21 in walk behind lawn mower doesnt self propel..cable appears to be intact
You should inspect the belt, this may mean that you have to remove a cover.
If really helpful, please rate.
Jul 12, 2011 | Garden
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
6.5 toro walk behind self propell b&s engine. self propel does not work
Aug 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
