Question about Alpine Car Audio & Video
My alpine 3516 amp plugs have been cut off and I need a wire diagram plz
KaeZoo
  • 156 Answers
SOURCE: wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Posted on Jun 06, 2007
  • 631 Answers
SOURCE: Wiring diagram for Alpine MRP-F300
From the Crutchfield site:
Owner's manual
You'll use fig.8 for the front speakers and fig.9 for the subs.
Posted on Sep 05, 2008
dontbother10
  • 2220 Answers
SOURCE: Need to remove & replace primer bulb on mcculloch mac 3516
There are 4 different IPLs for this saw. Fuel detail are on multiple illustrations.
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
A helpful video, a few of my suggestions, and a schematic follow:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Nov 16, 2009
SOURCE: I have an Alpine 3311 Eq, a 3512 amp and a 3518
I have the 3311 manual. Do you still need it?
  • 1121 Answers
SOURCE: where to get the wiring diagram for the alpine ktp-445
the wiring diagram is the same as your stereo , check for your actual stereo manual use the same pins layout.
Posted on Jan 16, 2010
Friend of mines gave me a alpine 3516 power amp, was just wondering if I can hook it up or even use it for a stock stereo
Yes it can be used with most stock stereos. If you've never interfaced an amp with a factory radui before i highly recommend having it professionally installed.
Nov 01, 2016 | Alpine Car Audio & Video
Need wiring diagram for alpine amp. mod.#3533
What does a black wire hook up to it's coming off the board jp8
Jan 11, 2015 | Alpine Car Audio & Video
Pontiac grand am wiring diagram
You will need the wire harness that is designed to connect to the stock stereo. Another option is to just install your alpine stereo in the car since you have the wiring harness for that. You will not be able to wire the harness for the alpine unit and have it match the plug type for your stock stereo.
Dec 12, 2013 | Alpine CDE-121 In-Dash CD/MP3/WMA/AAC Car...
I ran across an Alpine 3516 amp. my problem is both plugs are cut off the input and output wiring harnesses. There is a set of small wires and a set of bigger wires which is which ?
Most of these in the day where proprietary and only worked with an alpine set up. If you want to try I think the small wires are for the RCA inputs and the larger ones would be speakers and or power and ground. You should know how to use an multimeter and have a DC power supply that is fused or has a circuit breaker.
Oct 01, 2013 | Alpine Car Audio & Video
Am wiring my alpine car stereo back to my old car , unfortunately i dont know were to connect the wires , the labels on the wires somehow got cut when i kept it in storage , need help figuring were the red...
First thing you will need to do is to buy a wire adapter for your specific make & year of car. This interfaces the stock wiring plug allowing you to connect the wires from the headunit to the wires of the plug.
Here is a color coding explanation for the wires on your Alpine Deck:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Mar 17, 2011 | Alpine TDA-7563 Cassette Player
Where to get the wiring diagram for the alpine ktp-445 power pak amp. want to cut the plug off so I can wire to a different reciever/player
Jan 16, 2010 | Car Audio & Video
Need wiring diagram ktp445 to be installed on a NON alpine unit
please, I need wiring diagram for a alpine ktp445.... to be installed on a NON alpine unit.
thx
dave
Dec 06, 2009 | Alpine KTP-445 Car Amp
Stereo diagram for 1990 geo prizm
Hello stoogieprezi,
You should have gotten a plug-in harness with your new Alpine. To avoid cutting or tapping the wires on your vehicle, you need to purchase an aftermarket wiring harness. It appears that the Metra 70-1782 is the correct one for the 1990 Prizm.
Then you simply match up the wires on your Alpine harness with the Metra harness. The wiring color code for the harness is shown on the bottom left of the "description" tab and matches up with the Alpine color code on page 18 of your owners manual.
Hope this helps.
Jun 10, 2009 | Alpine CDM-9821 CD Player
Car Audio & Video Logo
103 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
