Navien 240 unit. continuous E109 and occasional E110 code.cleaned screen many times, Cleaned the fan motor, cleaned air intake and exhaust. Doesn't shut down as much with the cover off the unit?
Marrie
  • 563 Answers
SOURCE: System shuts down
Hi labiancad
Were you able to see if all of the fans are working ?
Is there any of the LED's on the Projector flickering and what colour if they are ?
Posted on May 28, 2008
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
  • 105 Answers
SOURCE: Unit runs for 4 seconds and then shuts down
there are led sensors on the bottom of the cutting head above the bin . they are either dirty or defective.
Posted on Dec 04, 2009
hardrocko
  • 1476 Answers
SOURCE: R55B Reddy Heater won't stay running. (PMS? menopause?)
Wow! Yours is the best description of a problem I have ever seen!!! Before I read the whole thing I figured you missed the pressure check as most people do but you nailed it. This is what I would try, Replace the air filter, the fuel filter, and the fuel (to make absolutely sure there is no water in the fuel) and readjust the fuel/air mixture. If that does not do it replace the cadmium cell they only cost pennies. Let me know how you make out and good luck.
hardrocko
PS, I have one of these so I am pretty familiar with the problems.
Posted on Feb 03, 2010
SOURCE: Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Posted on Feb 09, 2010
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Code 12 is displayed on unit-- directing to a combustion air problem
Code 12 is flame failure check out any over heat sensors
Oct 11, 2016 | Rinnai Heating & Cooling
How do I clean the combustion air intake?
If you are talking about between the outside and the gray flex pipe, remove the pipe and blow the stuff back outside. If it is beyond the gray flex pipe, then a disassembly will be necessary.
To prevent further entrance of anything, debris / bugs to either the intake or exhaust, see my modification to the intake/exhaust pipe here: Thread Toyostove Exhaust Bug Shield .
Jan 08, 2015 | Rinnai Toyostove Direct Vent Heater:...
Gas package unit
the bushing or the bearing in the motor may have already worn out. or may need some lubrication. the rotor is trying to turn but it's stiff and won't continue to turn. dont continue to turn on if it wont spin otherwise you'll damage the motor further. it might also be the busted capacitor "if it has"
Jun 04, 2013 | Amana Heating & Cooling
Whirlpool/Honeywell hot water heater light flashes 5 then 7 times and won't light. Burner is clean and all contacts are good. Out of warranted.
Copy following link to troubleshoot by type of gas control valve, including directions for cleaning air intake screen, and or replacing gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7 flashes: Gas control valve might be bad.
4 flashes: FV overheat, clean air intake.
Soot indicates clogged air intake slowed combustion venting possibly causing overheating and lockout. Clean air intake screen located on bottom of unit.
Apr 17, 2013 | Water Heaters
I cleaned the outside unit of our Coleman Evcon central air conditioner today with a power washer. Now the fan is squalling, sometimes it sounds like morse code, sometimes it continues uninterupted for a...
Hopefully you didn't get the motor wet or any other electrical components. It sounds like you may have a motor with dry bushings. There may be an oil plug in each bell end of the motor. You can use thin weight oil , about 5 drops into each bushing should do it. If this doesn't work or it doesnt have oiling holes, the motor may have to be replaced Other wise, if you got the motor wet it may short out. In that case you would also have to change the motor
Jun 20, 2011 | Coleman Heating & Cooling
My Napoleon NPS40 pellet stove's exhaust motor is running continuously and the ignitor won't heat up. I've cleaned the stove and look at the reset button, all seems fine.
Check the door gasket material. If it's worn, it's allowing air from the room to be pulled in and has fooled the exhaust motor into thinking it needs to run more. Or the fan ON/Off sensor has failed.
Mar 28, 2011 | Heating & Cooling
I dont understand how the intake and exaust features work, and the temp guages work? i just use max speed ,
mcdevito75 here, The intake and exhaust feature is simply a reversal of the fan motor or motors. On intake all the air is being brought in from the outside to inside your home, this is fine for the spring and fall, but in the summer time when it"s both hot outside and inside your home you"d want to use the exhaust feature to get the hot air out of your home and let fresh air from the outside in. The temperature settings, unless your fan is actually an air conditioner and not a window fan are the fan motor speeds, you set these speeds to suit yourself. If this unit is an air conditioner you can set the teperature aorund 65 degrees or approx. Half way thur the blue sash on the knob or half way between cool and cooler depending on how your teperature settings read.
Jul 19, 2010 | Lakewood LPRW3 Window Mount Fan
My laptop fan over heating
try getting a can of compressed air from an office supply retailer and blow the dist and debris out of the ventilation and air intake ducts.
Sep 17, 2009 | Acer TravelMate 4200 Notebook
Heating & Cooling Logo
261 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
