Question about Sewing Machines
Does this machine automatically thread the needle
  • Sewing Machines Master
  • 11,494 Answers
Can't tell since you didn't list the make & model.
FWIW, no machine "automatically" threads the needle. Some machines do have a needle-threader apparatus attachment but it is user manipulated.
HINT: To make needle threading easier, do NOT lick the thread end. Instead, lick your index finger and swipe it across the BACK of the needle's eye. When you put the thread end up to the needle's eye, the thread will literally "jump" through the eye!!!
Posted on Apr 26, 2017
Top thread is shredding Automatic needle threader stopped working
If the top thread is shredding it is usually because the needle and thread are not compatible. If thread is too large for the eye and the thread groove, the action of sewing will cause the thread to shred as it pieces the fabric.
Try a different needle and thread. Here's an excellent web site:
All About Needles
Sep 27, 2015 | Sewing Machines
Difficult to use auto needle threading
you thread the machine the normal way, using every thread guide, and if the automatic theader works it will thread the needle,
if the auto threader doesn't work, then it needs to be checked.
also make sure the needle is turned the correct way and inserted correctly into the needle holder.
Mar 06, 2014 | Brother 50-Stitch Limited Edition Project...
Juki locked
hi thereis your machine automatic thread trimmer or manual?
if automatic machine maybe movable knife is locked or there's some thread in between.
if manual maybe hook finger ( stopper ) is have thread or there's thread inside hook and need to clean. also same at automatic.
second. maybe needle bar is locked please try to loose the screw for needle par and check machine manually move or still locked.
Dec 31, 2012 | Juki DDL-8700
After automatic thread cut the needle comes unthreaded
you need long thread tails, of 3 to 6 inches for the top & bobbin thread so the needle doesn't come unthreaded,
also pull the thread behind the needle before you start to sew
Mar 27, 2012 | Brother PQ1500S Computerized Sewing...
Top thread on my Brother Limited Edition 350 Sewing machine keeps breaking. Having used the automatic cutter, the thread pulls up and out of the needle when I want to start sewing again. Also the machine...
rethread the machine
try a top thread tension of 3 or 4
change the needle
always keep a thread tail of 3-5 inches on top & bobbin thread & keep the thread pulled back behind needle before starting to sew
always keep the bobbin area clean of lint & loose thread
& check under the needle plate for lint also
you might consider having the machine serviced, since you said it sounds like a tractor
some needle & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 04, 2010 | Brother Sewing Machines
How to thread a dual sew 3300?
Rather than seek a lengthy explanation it will be good that you follow the guidlines in the manual received along.
Starting from the bobbin at the top the thread must be passed around to reach the needle in the sequence described.This machine ahs a automatic tthreading and so the automatic threading feature enables the machine to thread itself from the top thread spool through the eye of the needle.
Sep 14, 2010 | Dual Sew 3300 Mechanical Sewing Machine
Quantum XL-6000 automatic threading system not working
ok it sounds like the theader is bent check to see if the that it is going through the eye of the needle if it is make sure the foot is up so the tenison dics holding the thead this may help .
Nov 24, 2008 | Singer Quantum XL-1000 Computerized Sewing...
How do I thread it
Follow the thread from the spool through the first thread guide at #1 straight down to #2 and up to #3 (make sure that the thread is through the take-up lever (silver hook) at #3 from three you will bring the thread straight down to the thread guide that is to the left of the needle. Thread the needle from front to back.
Mar 11, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
