Question about U-Line Refrigerators
How to replace door gasket on under counter u-line ice maker model uln b198 wh-oo
3 Suggested Answers
SOURCE: NO POWER GETTING TO UNIT
realized that there was nothing wrong with the unit....It is suposed to drain out water when running and need to jump start it...so alls good thanks for getting back to us...now were chilling.E.Bates
Posted on Jul 15, 2008
  • 93 Answers
SOURCE: wiring digram for under counter uline ice maker
It is on the back of the machine, if you have clear ice maker, it may be on the back of the front plate.
Posted on Mar 02, 2010
Water leaking from ice maker
Make sure normal drain line (located under the ice) is not clogged. Check gaskets and seals. Also make sure everyone who uses it closes the door completely and does not leave it cracked open. And make sure no one has screwed any thing into it and punctured through it. A screw alone will not keep the water in.
Feb 24, 2015 | U-Line Icemaker
I have a U-Line ULN B198B-00 and the water won't shut off. It ends up filling the ice bucket and overflowing. Could it be a bad solenoid??
If you can get to the solenoid you could remove the solenoid connector. If it shuts off then I would suspect the ice maker timer. if it doesn't shut off I would suspect the water valve/solenoid.
Aug 16, 2014 | U-Line ULNSS1095 Marine Series 12-lb...
Model b198 makes one batch then stops
Check the bin arm spring you will have to disassemble the front of the ice maker to do this and check timer motor could be getting hung up. not a cleaning problem. or replace the complete head.
Oct 09, 2012 | U-Line Icemaker
Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
www.u-lineservice.com
Jun 05, 2009 | U-Line Refrigerator Ice Maker
U LIne B198- Makes a batch then quits
Ok first thing is replace the control with a u-line part. yellow is common and red is for harvest and blue is for compressor and fan. yellow and blue would make the compressor and fan to run. but you will not have an icemaker.
Apr 26, 2009 | U-Line Icemaker
Jul 07, 2008 | U-Line Icemaker
Refrigerators Logo
43 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
