SOURCE: kidde Carbon Monoxide Alarms
YES!!!! If this unit is working properly you should not be in the house. Maximum allowable safety level for an 8 hour period is 50! If you think it's working properly call the fire department! This will cause dizziness,nausea,etc. Let your fire department find the problem! If you don't believe me follow this link to owner's manual but do it quickly: http://www.kiddeus.com/utcfs/ws-384/Assets/KN-COB-B(9CO5)en.pdf
SOURCE: my kidde smoke and carbon monoxide alarm keeps
You will need to remove the unit from the ceiling to reveal the battery compartment on the back. It should just need to be rotated counter clockwise a small amount and will then come loose from the bracket. When installing a new battey be sure to press the battery reminder finger down into the battery compartment or the battery door will not close. Call the Kidde (pronounced kid-a) hotline if you have problems 1.800.880.6788
SOURCE: kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
SOURCE: kidde smoke alarm won't stop chirping
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
SOURCE: I just fixed a new Kidde alarm hardwired with both
The normal condition for the green LED is solid. A flashing green LED indicates memory of a prior alarm condition. Press the test for at least 2 seconds to reset the detector memory.
