Question about Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer
Can not send fax
What is the proper connection to phone line
  • Anonymous May 11, 2010
    A wire from the machine to the wall jack. That's it. If that doesn't work....you either have a problem with the machine, or you don't know how to work it.
    Brigadier General:
  • 4,090 Answers
Thyere are two phone connections on printers Phone which allows you to use the phone line normally and a second port that is a line that allows both IN and LINE OUT. Make sure you have connected the plugs correctly they usually have symbols to guide you phone symbol is for phone extension... the other can be a Fax symbol which is the one that goes directly to the wall outlet
Posted on Jul 25, 2009
How do you fax papers?
Make sure the fax machine is properly installed with an operational phone line. Put the papers in the fax machine (ensure they are facing the proper direction). Dial the number you want to fax to, ensuring you have the proper codes for external lines and long distance calls if required. Push the start button. The machine will scan your documents, dial the number, and send the faxed documents when a connection is made.
Mar 11, 2015 | Office Equipment & Supplies
How to send regular fax from a bizhub c250
fax line connected to a analog phone line can not be digital, is the fax line plug, phone line good call it and problem or nise.ed into the line connector not the tel connector fax kit installed properly and set up correctly
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Apr 02, 2014 | Konica Minolta bizhub C250 All-In-One...
How do i send fax from bizhub 250
Fax line connected to a analog phone line can not be digital, is the fax line plug, phone line good call it and problem or nise.ed into the line connector not the tel connector fax kit installed properly and set up correctly
try this site
Apr 02, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Sending fax error message."Phone
No. Most of the time this "phone line error" can be caused by the telephone connection or issue on the phone line where the fax machine is connected.
Hope this will help.
Mar 27, 2011 | Office Equipment & Supplies
Cannot send a fax
For a fax to work you do not need a broadband. What you need is a phone like. It seems that you are trying to use broadband for fax because it is the same phone line that they both are on. Sorry, will not work that way. If you trace back you will find that there is a little box that has the phone line coming into from outside. The box splits it into phone and dsl. It is this phone line that should go into the fax and not the dsl line.
So please remove the dsl line from the fax and connect the phone line and you will see that the fax works.
Dec 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
I CAN SEND FAXES BUT NOT RECIEVE
The majority of the time, when you can send but not receive, it is a phone line issue and not the machine. Extremely rare does a machine send and not receive. So here goes the things to try and the reason. 1, Make sure the phone jack is in the "Line" jack and not the external phone jack. Believe it or not, that is the number one issue with sending and not receiving.
Next, plug a phone into the jack that the fax machine is plugged into and see if there is static.
You want to be sure in the fax \settings and advanced settings that the ECM mode is ON, and that Junk Fax ius turned OFF, Junk Fax being on will stop almost all fax from comming in.
Now, the phone line. Here is the explaination of why that can be the problem. When you send a fax, you manually make the connection to the line. When you press send a relay flips and connectes you to the phone line, therefore you have made pretty much a mechanical connection enabling the phone line, and therefore you can send.
Now, when you have an incoming fax, several conditions must me met to make the handshake and therefore connect and receive. These all have to be right in order to properly receive. The phone line voltage mist be high enough, the phone line current must be correct and there can not be much decibel loss over the line. You are making a signal connection, all those conditions must be right to receive a fax. Think of it like a TV remote with batteries that are almost dead, It still send out some signal, but it will not change channels or change the volumn,etc etc. Same principle. If the signal to the incoming fax is weak, chances are it will not connect.
Jun 13, 2009 | Office Equipment & Supplies
Cannot send fax with a proper working phone line hooked up
I have exactly the same problem! did you find a solution or reason???
Mar 19, 2009 | Brother MFC-9440CN Laser Printer
Receiving and sending faxes
if the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
Mar 04, 2009 | OKIFAX 4580 Plain Paper LED Fax
Fax machine will send out but will not receive any
Sep 24, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer Logo
62 people viewed this question
Top Digital Products Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alan Rothery
Alun Cox
Are you a Digital Products Office Equipment and Supply Expert? Answer questions, earn points and help others
