Question about Sport & Outdoor - Others
Ajusting the let off on a pse baby g force
How do you adjust the let off on the pse baby g force mossy oak camo with the wood grip
4 Suggested Answers
One Wire
  • 126 Answers
SOURCE: front cover and mike
This guy does a pretty good job with faceplate stickers. He has a lot of radios listed on his site, but if your radio is not listed, contact him, and he will see if he can come up with a template.
http://mtndewnutsales.com/Faceplate_Page.html
I have used him a couple times and he is pretty respectable.
Posted on Oct 11, 2008
al_kupchella
  • 843 Answers
SOURCE: Blade guide bushes melt/wear with hard wood
If these bushings are getting that hot, then you may have the wrong speed or a non-optimum blade. The blade pitch (number of teeth per inch) must be lower the thicker the wood is. If there are too many teeth trying to cut at the same time you have to push harder to get enough pressure to cut and that puts more force on the guide bushings. There are a variety of pitches available even for the narrower scrolling blades. If you have to move up to a wider blade, there is a little trick to help you cut a slightly smaller scroll radius - round off the back side of the blade with a sharpening stone.
Also, with oak, you may need to use a slower speed to keep the blade from heating up - although a hot blade will show up as more of a problem with the lower guide bushings only. Your saw might have multiple steps on the pulleys, allowing you to move the belt to a slower speed.
I hope this helps. Thanks for using Fixya. Good luck!
Al K
Posted on Mar 24, 2010
dontbother10
  • 2220 Answers
SOURCE: I cut mostly hard woods, oak, hickory etc. I just
Have the chain professionally sharpened (Stihl or Husqvarna) at a saw retailer (take your saw). While there ask them to verify the gauge of the bar and chain are the same. When you return to pick-up your chain bring a few pieces of wood. Ask them to make a few cookies with your saw. Please reply with the result.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 28, 2010
Can the wheel bearings on a 1998 Ford Explorer be greased?
  • On 4x2 vehicles, adjust the front wheel bearings
  • On 4x4 vehicles, install a new wheel hub (1104).
  • So: yes on 2WD, No on 4WD
Sep 18, 2014 | 1998 Ford Explorer
Tip
Woods i use for smoking meat
Here's the list of what woods i use; Hickory-
The last hickory I used for smoking is from a tree I cut down that was growing in the woods on the family farm. The trunk was about 8 inches in diameter, so I ended up with a lot of wood to use, and a lot to share.
Mulberry
I've used quite a bit of mulberry wood. It's common here in Southcentral Kansas. I've even have a couple mulberry trees in my yard. Birds spread mulberry trees by eating the berries, then transporting the seeds internally (in their droppings)
Red Oak-
I've used this wood quite a bit, usually when smoking beef briskets and pork ribs. The flavor is not as rich as that of hickory.
White Oak-Another native tree on the farm, these are much smaller than the red oaks. The flavor is similar, but can be a bit harsher than their red cousins. Squirrels and whitetails love the acorns from white oaks.
on Aug 17, 2010 | Grilling
Fore end loose
If you contact the manufacturer all PSE crossbows have a lifetime warranty and for safety reasons they will repair for free.
Mar 27, 2014 | PSE Precision Shooting Equipment PSE...
Where is the idler screw on a Kawaski 360 prairie atv
To ajust the idle there is a nob that you turn that come from the carb,
Jun 10, 2013 | kawasaki 2007 Prairie 360 4x4 Camo
Mossberg model 88 manual
Yep. The back end of a Mav 88 is identical to the Mossy 500. Same gun, after all. The front end, forearm is the only real diff accessory-wise. You'd need to buy a Mossy action tube (the forearm steel) to put a forearm on your Mav. Stock, yes....forearm, no.
May 17, 2013 | Optics
What are the differences between bamboo and solid wood floors?
Bamboo is much more environmentally friendly than solid wood as bamboo regenerates in time. Moreover, bamboo is harder than some solid woods such as red oak and black walnut.
Feb 06, 2013 | Building Materials
Does laminated floor look like real wood?
Absolutely, using photographs, laminates lock in the realism of hardwood strip. Nowadays, laminate floors offer an unparalleled level of realism making the floor look like real wood.
Jan 10, 2013 | Building Materials
User instruction manual
Check out this web site. Hope it helps.
http://www.bushnell.com/manuals/riflescopes/GenericBushRS6LIM.pdf
May 03, 2010 | Bushnell Banner 3-9x40 Rifle Scope Mossy...
Al K
Mar 21, 2010 | Saws
I want to know how to camouflage a jeep the best
Knowing how to paint a Jeep in camo patterns means you can hide your Jeep in the woods, marshy areas or in open fields without it being easily seen. Using Mossy Oak's Shadow Grass pattern, paint your Jeep with natural-looking shadows and grass blades. The 3-D look of this pattern allows you to easily hide your Jeep from water fowl, doves, deer and big game.
Things You'll Need:
  • Sandpaper (120 and 800 grit)
  • Wax and grease remover
  • Lint-free towel
  • Camo stencil
  • Masking tape
  • Masking paper
  • Respirator mask
  • Automotive primer
  • Automotive paint (black, gray, light tan and brown)
  • Automotive clear coat
  1. Sand the surface of the Jeep with 120-grit sandpaper until the surface is dull. You can use a dual-action sander for this step to speed the process. This removes the top clear coat and prepares the surface for primer. Primer won't stick to a shiny surface.
  2. Mask off areas of the Jeep that won't be painted, such as the windows, tires and passenger area of the Jeep. Wipe the surface with wax and grease remover and a lint-free towel.
  3. Spray primer on the Jeep in three thin coats. Allow each coat to dry completely. Once the primer is dry, use 800-grit sandpaper to sand the top layer of primer until smooth. This leaves a smooth surface for the paint. Wipe again with wax and grease remover and a lint-free towel.
  4. Paint a thin base coat of gray on the Jeep. Cover all of the primered areas on the Jeep so that no primer can be seen. Allow the paint to dry.
  5. Go over the Jeep with brown paint, spraying small areas of brown paint in no particular pattern. The finished effect should look like the Jeep is equally painted gray and tan. Hold the first stencil against the Jeep and use black paint to fill it in. Move the stencil over and paint again. Start at the front of the Jeep and work towards the rear.
  6. Move on to the next stencil and use light tan paint to spray the grass pattern. The grass should start at the bottom of the Jeep and reach up towards the top. For longer grass, don't spray the tops of the grass but instead move the pattern up, spray the stems longer and then spray the tops, making the grass stems long. Repeat this around the Jeep and across the hood. Go back over the grass stems with black paint, lightly spraying a few of the stems to give them a shadow look.
  7. Finish by spraying three coats of clear coat paint onto the painted areas of the Jeep. This protects the paint from UV rays and keep the camo pattern looking good.
Tips & Warnings
  • Paint is best applied using a paint spray gun and air compressor, but canned spray paint will work.
  • Never sand or spray primer or paint without using a painter's respirator mask.
Resources: Customice Camo Stencils
I really hope help you with this (remember rated this help) Good luck.
Oct 21, 2009 | 1984 Jeep CJ7
Sport & Outdoor - Others Logo
643 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
