Question about Refrigerators
Line 2175srod-01 will not turn on light not working has power but can't turn unit on. Is it the control board bad?
3 Suggested Answers
  • 286 Answers
SOURCE: My U line model 2015rs just quit working. Power
Thermostat is more than likely bad. Nothing runs but light is on
Posted on Oct 08, 2009
espressonist
  • 1711 Answers
SOURCE: Compressor and fan are running
which is your model and brand.
How is the temperatures
Posted on Nov 03, 2010
FAN NOT BLOWING ON INSIDE UNIT, CARRIER FX4CN042T00AAAA LAST TIME IT WAS SOMETHING ON A CONTROL BOAQRD THAT HAD A RED LIGHT ON IT, QUESTION WHERE IS THAT LOCATED?
If your outdoor unit has a control board/circuit board, it will located at the outdoor units electrical panel where the line voltage electrical whip goes into the unit. Should be 2 screws that hold the panel/cover on. Turn off power, remove panel, and board should be visible.
Mar 30, 2017 | Carrier Heating & Cooling
Dryer will not turn on. Lights blink and the Code "F-01" shows in the display
depending on your model The F-01 error code indicates a primary control board failure . If the error cleared after unplugging it for a while, then the control board could have received a power surge or glitch through the electrical lines. Completely disconnecting the electrical power and then reconnecting it will sometimes reset the board and it will operate properly. If your dryer continues to operate properly, then resetting the control board may have fixed your problem.
If the dryer motor continues to stop, then you may have a bad control board. A wiring problem or drive motor failure could also prevent the dryer from continuing to run properly. A technician is normally needed to diagnose and repair this type of problem.
If the F-01 returns and will not clear, then you will need to replace the control board in the dryer
Nov 25, 2015 | Dryers
Changed door switch and still its like the dryer has no electricty
The nicest problem would be that one side of the 220VAC power line is dead, possibly due to a bad circuit breaker. The drum light runs off one side of the line only, but everything else requires 240VAC (i.e., both legs of the line.) So, if you're really lucky, you could turn off the circuit breaker, turn it back on, and everything will work. If you've got a voltmeter handy you could also verify 120 VAC between each leg and neutral, and 240VAC between the two legs.
If your incoming power os OK, it's an electronic control (aka main circuit board, computer board) problem. The solution could be as simple (and cheap) as just reseating the connectors going to that board, or as simple (but expensive) as replacing the board.
Sep 14, 2012 | Kenmore Elite HE4 Electric Dryer
The fan inside the furnace cycles on and off several times before finally turning on completely.
You may have a variable speed blower that is not wired correctly to the thermostat or the problem could be the ciruit board.
Nov 10, 2017 | Ruud Rheem Control Circuit Board...
Kenmore elite dishwasher 66513922k010
So, you have power on both sides of the fuse, huh? How did you test that? Did you use one of those voltage detectors that light up when they get near a "hot" wire? If so, then I would tell you to make sure your white return line (neutral line) is NOT hot, because if it is, then you probably have a bad connection in your junction box for your white (neutral) line. But if all that's fine, then you EITHER have a bad control console, or a bad control board, and I would bet it's the control board.
Jun 20, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Sep 28, 2009 | U-Line 15R Compact Refrigerator
No indication of power to the unit. I opened the unit and removed the cable connecting the main board to the LCD controller board. I disconnected it from the LCD controller board side. When power is...
If you hear a flickering sound the power board is bad .However since you have found the lcd board to be faulty you might as well replace it.Look for it on line by part number.Or to save yourself some headache use a good board from a working monitor.
Good luck
Sep 16, 2009 | Acer AL1923 19" Monitor
Came home today and the AC will not come back on. The out side unit is working, but the blower inside will not come on. Also the light on the control board will not light up at all. Does anyone hav
turn off power to indoor unit feel the fan motor if hot and turns rough bad if hot and turns smoth then most likley capacitor if cold check 5 amp fuse on the board jump red stat wire to green if no fan relay bad if fan stat bad hope this helps
Jun 03, 2009 | Goodman CLJ30AR32 Air Conditioner
Sansui dvd recorder SAN0901
turn the power on. to get rid of the red light you need to press the timer/rec button on the remote until it turns off. the red light means it is programed to record.
Dec 01, 2007 | Sansui VRDVD4005 DVD Player/VCR
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
