Question about Toro Garden
Toro self propelled will start but will not keep running. Shuts off within seconds. What. An I do?
    Top Expert:
  • Toro Master
  • 12,650 Answers
Most likely carb rebuild needs tune up or bad gas
Posted on Apr 26, 2017
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Toro self propelled rear mower recycler.. starts and runs fine..Then stops if you do not keep the propulsion in gear
I would say that something inside the mechanism that engages the self-propelled action has broken. When you release the lever, (most of the way), that keeps the S.P. action moving, it's suppose to flip the action off but keep the motor running. And when you release this same lever all the way, it acts as a kill switch. If your wheels never disengage, then I would look at the mechanism spoke of above.
If you hear this mechanism click when you release this lever, this is good and it's not broken. Then you may have grass and junk clogged up under the cover where the front wheel is. This would also keep it from disengaging.
Good Luck!
Jim
Aug 19, 2011 | Toro Power Lawn Mower
My toro self propelled lawn mower won't roll backwards... the wheels are locked up
My Toro Pace Master self propelled 22" 6.75 mower will not move by itself. I can push the mower and cut. It does start with no problem. I have a cable on left side of the mower that extends to the top of the handle broken off at the top of the mower and is loose. Is there a way to check to see if this is why it will not self propel. It attaches to the push handle that does I push down to propel the mower. Any suggestions?
May 07, 2010 | Toro Lawn Mower With Toro Power Tools
I have a toro commercial self propelled, engine stops when I engage the self propelled. I t runs until then. What can I do to solve this problem?
Regularly check the wheel-drive belt on a self-propelled mower for wear and tightness .... "Affected engines may run rough, stall or bog down under load,"
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
I have a TORO 6.5HP Mower Model #20017 Self Propel Drive-
check cable.check belt and check gearbox.one of these will be bad.if not all
Jul 21, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Can't start toro mower. cleaned spark plug , new air filter . will run for 2 or 3 seconds on prime , then stalls ,will fire every time , but won't continue to run what next? 22" self propelled...
Hello:
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
