Question about Indesit Washing Machines
Indesit 1100 WIL113 lights flashing delay timer and easy iron stops 2 mins after putting on drains fine and spins. Any help thanks
3 Suggested Answers
  • 197 Answers
SOURCE: lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
Posted on May 09, 2009
carpreach1
  • 42 Answers
SOURCE: wil113 indesit delayed timer and start buttons
timer is not working properlly, replace it
Posted on Aug 12, 2009
We just bought a second hand Ariston Washing Machine model AVL 95. It works fine all programs, but when it goes to spin, it starts to spin, speed up, and then stops with an error (Delay Timer flashes and...
its the drain pump see if you can take it out there small and easy to get to,also you see a black ribbed hose that goes to the drum to the pump see if there any thing in it.The drum is inclosed.try running 2xclorox through machine.
Jul 05, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
Nov 30, 2017 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Lights flashing on indesit WIL123S
and replace.
May 09, 2009 | Indesit W 123 Front Load Washer
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
