Question about Whirlpool Washing Machines
Whirlpool AWM8121 flashing 0,100,400 rpm lights,the wash light and start light. i have replaced motor brushes.
chad7houston
  • 62 Answers
SOURCE: Whirlpool AWM 6100/s Front load washer
Sounds like the front door switch has come out of place, or the actuator is out of place. If you can take the front cover off to get to this switch, you should be able to get it back into place pretty easily. Hope this helps, chad
Posted on Nov 01, 2008
  • 4 Answers
SOURCE: Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Posted on Dec 13, 2008
  • 4 Answers
SOURCE: Whirlpool AWM8121 stops working mid
Fault code 3 = Drain failure or not detecting empty drum.
Check pressure switch, blocked drain, drain pump.
See link below for service manual.
http://www.user-manuals.com/advanced_search_result.php?keywords=857081253000&forward=plist
Posted on Dec 15, 2008
  • 18 Answers
SOURCE: Hotpoint WF430 lights flashing will not start
Hi, the problem is the pump is blocked. What you have to do if your a bit handy is to turn off the power from the plug socket, pull out the machine and take off the back panel, then when you look iside you will see a big black rubber fitting at the base of the mashine attached to a white plastic pump and inturn to your outlet pipe. you have to disconnect the big black one from the top, there is a metal clip which you have to unscrew and it will fall down. inside this is a plastic ball and something which looks like a shuttle ****, take this out and clean everything, you will be suprised what is in there (especially if you have kids) lastly put everything back together and put on a quick rinse cycle. all is fixed! OR Call an repair man, who may try to con you into new parts when they are not neccesary.
Posted on Aug 31, 2009
SOURCE: frigidaire dishwasher FDB1050REB0 flashing washing light but doesn't start
Fliped the circut breaker and got the 3 blinking lights and hit start and it ran fine.
Posted on Feb 21, 2010
Whirlpool 6th sense wont start cycle
I have the same problem. Look at the previous post, it seems to be the motor brush worn out. I've opened up the machine and checked. The carbon brush remains very little. I am trying to find out a replacement brush
Dec 27, 2013 | Whirlpool AWM6100 Front Load Washer
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
Machine stops, "door open light" flashes door is securely shut.
bad door lock and or harness replace door lock assy and check all connections
Jul 07, 2009 | Washing Machines
Whirlpool AWM8121-The Rinse and Door open light blinks constantly
This error code means there is an abnormality.
If the on-off door lock LED on a Whirlpool washer flashes rapidly at the same time as at least one other LED, then this means there is an abnormality.
Try first to reset the machine. You can press and hold the reset button for a couple of seconds, otherwise turn off the power completely (unplug it) for 5 mins.
Mar 01, 2018 | Whirlpool AWM8123 Front Load Washer
Flashing lights on Rince, Start & 0 speed.
washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
Dec 13, 2017 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM8121 stops working mid cycle. Bottom two lights flashing on spin speeds.
Oct 24, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM8121 ?door open? light flashing and washing machine won't start. I had solved this same problem over a year ago. It seemed to be the door locking solenoid not working. I solved the problem by...
Jul 20, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
