Question about Kitchen Ranges
Hi i have a univa stove. At the back is 2nuttral and 3live plus the eard . pleas help don't know how to connect it up what type of wire ring to use
2 Suggested Answers
SOURCE: need wiring diagram univa stove /oven model ph14s
Were do I get the skimatics for a stoves wiring as I have to put the regulater back to geather as old one fell apart.
Posted on Oct 28, 2010
The black tinted outer glass of my univa stove broke in pieces, can you replace it or make another glass the same?
Go to appliancepros.com and put in your model number and look up the glass. They will give you the price. I know on most models u can order the glass without buying the whole door.
Apr 23, 2014 | Maytag Ovens
Hello a couple of our stove tops rings intermittently work and now one has stopped working altogether. The light comes on but the ring does not heat up. Any advice? Thanks so much
Hi unplug the stove and remove the two screws that hold the top down, holding the burners, check for burned wires going to and from all burners I think you may have wires that are shorted out , or the element itself is burn out , you can check this with a ome meter, by putting each wire on the ends of the element , I hope you know how to use a meter if not write back and I will walk you though it , Just look around very carful
Feb 21, 2011 | Maytag CWE4800A Electric Single Oven
Need wiring diagram univa stove /oven model ph14s
Jan 22, 2010 | Ovens
HOOKING UP STOVE TO POWER OUTLET IN HOUSE....
you need to take the back of.down the bottom should be power terminals.positive ,earth and negative,earth is green,negative is black or blue.the earth is to be puy on thee screw.if you undo a screw then the wires will clamp in when screwed back.a stove should be hard wired to the house if you use a power leadto a power point you can not use all of the stoves functions ,it will trip the fuses
Sep 25, 2008 | GE JDS26 Electric Kitchen Range
Dimplex DS5598
Disconnect power to unit before attempting to repair unit.
1.With the front door closed,gently place the stove, door side up on a flat surface.
2.Remove the heater assembly retaining screws located on the bottom of the stove with a screwdriver.
3.Lower the heater assembly off of the bottom of the stove being careful not to damage any of the wiring.
4.Disconnect the wiring clips and connections noting their original location.
5.Remove the heater assembly mounting screw and remove the heater assembly.
6.Properly orienate the new heater assembly and connect all of the wiring clips and connections.
7.Reassemble in the reverse order as above.
Pleas note, if you are not comfortable to do this please call your local dealer on Dimplex or go to the Dimplex website and they can locate someone for you.
Apr 06, 2008 | Dimplex DS5598 Mid-Size Heater
Kelvinator Stove Power Cable Connection
You should unscrew the small back panel, on the undercover should be a scetch of the wiring.
If not the three red are live, black is neutral and the g/y is earth, from number 5 to 1 connect as follows: 5 and 4-black,3,2,1 red and look for a screw type fitting or green wires to connect earth.
Its important to connect earth before operating the stove as it cuold lead to serious injury if not connected.
Hope this helps
Richard
Dec 23, 2007 | Stoves 1100ESIDLa Electric Kitchen Range
How do I connect the 3 phase / 4pin wires to the back of my defy compact stove?
You got it right,the green wire is ground.it should goto the grounding lug of the unit.
Dec 08, 2007 | Ovens
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
