Question about DeLonghi Ovens
Hello, I hope someone can help me! I am trying to fit a new element to a delonghi fan oven model ESF461 ST.
The element is held in place by one screw on the left and 2 pins in the plate and I can't see a way it can be removed from the front so I think this has to be done from the back. I have removed the door, the back plate and unscrewed the oven unit. I have managed to pull it out about a foot but it won't come out any further. Could anyone offer any advice? What could be preventing it coming out? Also, assuming I get it out, I'm a bit confused by the whole self-tapping screw business for fitting the element. I've not used these before... Shall I see what comes out and get some new screws the same size? Thanks in advance. Please keep answers simple! Caz
  • 3 Answers
SOURCE: Neff fan element
All of this can be done with the oven in situ. Take the back off if you like, but its un-necessary, dirty and time consuming. So here we go: Power off at mains. Remove 4 screws holding plate which guards the fan. You will be faced with the fan partially obscuring the top element retaining screw. At the centre of the fan spindle is a reverse threaded nut. WD40 the nut. Wait a minute or so and using a socket wrench and a flick of the wrist, the reverse thread nut should losen v easily. Having mastered the lock nut, tap the washer and it should become loose enough to remove by hand. If not, it just needs a little gentle persuasion with a flat head screwdriver where it sits on the fan itself. The grime will loosen and it will pop off. Squirt some WD40 onto the fan spindle, and wait a couple of minutes. Ignore any advice to lock onto the threaded spindle because if you damage it, your relatively cheap repair will become pretty expensive. Simply use a locking mole grip on the fan itself where the locking nut sits against it and pull and twist gently away from the spindle. You will be surprised how easy this is. Very little chance of damage. You can then access all 5 element retaining screws. Gently lever out the left foot of the element from the oven housing. Remove the spade connectors from the old element. Reversal of these instructions to fit the new element. Restore mains power. Reset clock or main oven will not work.
image_icon_name.gifSi Boon
image_icon_date.gifSeptember 2008
Posted on Sep 23, 2008
SOURCE: REMOVAL OF FAN
Ha - I found the solution myself. You need to remove the 3 screws securing the fan motor. Once you've done this, you can wiggle the fan a few mm, far enough to be able to remove the top element screw.
Posted on Jan 18, 2009
  • 25 Answers
SOURCE: Replacement of fan oven element on Nef U1721
Hi Steve...yes, these are a pain! Remove the centre fan nut (which is anti-threaded) then lever off the small locating washer underneath. If you are lucky, you will be able to now pull the fan blade off of the motor shaft. However, very often they won't budge!. If you try to knock it off, it is so easy to damage the fan motor (about £80!!). It is possible to leave the top bracket screwed to the oven and unclamp the element from it. I have come across three different typed of clamps so far. One is very easy to do. You can then remove the clamp from the new element and once the element is in place, use the old clamp. It's a fiddle but quite do-able. I have also come across these where the top clamp has been previously removed altogether by engineers on previous repairs! Hope this all helps a little....
Posted on Jun 25, 2009
  • 417 Answers
SOURCE: Can I change the grill element myself?
The grill element is not usually a 'plug-in' device.
You will have to remove the back of the oven/grill and disconnect it from the back before you can withdraw it from the front.
Remember to switch off the power before removing the back.
Posted on Jan 12, 2010
Testimonial: "Thank-you, just what I suspected. I will have to get professional help."
espressonist
  • 1711 Answers
SOURCE: in the top grill of
We have a video how to replace the grill element and a part of the video shows how the element is support with bracket and it might help you
Posted on Sep 11, 2011
Oven is not heating. Fan is working and grill wor...
This would appear to be the ring element around the fan that has failed and will need to be replaced.You will need to power off unit,then remove the back panel inside oven 4 screws in corners,Be careful with Thermostat held in place by clips above or on back panel.You may find 3 or 4 screws holding ring element.Gently pull towards you,being careful that the cables come with it.Check element with multimeter to see if open circuit if its ok then it may be a thermostat fault.If it is a faulty element,
get your replacement element,remove the cables off old one and put onto new one.Then push back into place and refix all.
Hope this helps.
May 21, 2010 | Electrolux EOB6630 Ultrafan Electric...
Ihave a whirlpool oven model gbs277pdo1 that will
this could be the timer is set to auto this data sheet might help For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Whirlpool GBS277PD Electric Single Oven
Need to put new bulbs and elements in fan oven
the bulbs are screw fit normally Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 12, 2010 | Ovens
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Electric main oven fan blows out only cold air
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 07, 2009 | Neff Ovens
I have a Neff U1721 circotherm oven. The lights come on and the fan works but it does not heat up. What could be the problem?
Nov 13, 2009 | Neff U1421 Double circotherm Electric Oven
Neff 1721 0ven element not working??
did you replace both fuses, if its a 240 volt element check the other fuse on the other leg of input power/120 volts + 120 volts = 240 volts
Oct 05, 2009 | Neff U1721 Double circotherm Electric Oven
Neff b1421n not heating up, grill and fan ok
breakers off ,,,back wall bottom center is a mounting plate 2 screws to take out the pull out wires and remove wires(careful not to let them slide back in)install new element...wires first the push back in place(no need to open back) don't forget breakers on now...you did it.... good for you.
Aug 25, 2009 | Neff B1421 Electric Single Oven
No heat on bottom oven. fan running but not heating up
Jul 19, 2009 | Neff U1421 Double circotherm Electric Oven
Delonghi oven grill broken, oven still works?
You will probably find it is the grill element that is faulty, a common fault on your brand of oven, to be certain, you need a meter to test it.
Please rate my solution.
Thanks.
Jul 15, 2009 | DeLonghi Ovens
Ovens Logo
32 people viewed this question
Top DeLonghi Ovens Experts
ashburton
Jason Harris
Jason Harris
Naftali Haskell
Level 1 Expert
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
