Question about The Office Equipment & Supplies
Fuser module (R3) has failed to reach operating temperature. swich the the machhine off. wait 1 minute. than swich the machine on again. pls help me
SOURCE: Runs until it gets to operating temperature then dies and won't start
No I haven't fixed the problem yet but don't think I want to pay not knowing whether or not anyone can help me. Thanks anyway.
Posted on Oct 05, 2008
glamarre82
  • 140 Answers
SOURCE: my 2000 max also revs up on its own.
Throttle position sensor or mass airflow sensor needs to be checked.
Posted on Jul 28, 2009
SOURCE: vehicle shuts down after reaching operating temperature
In side the left corner of the glove box is a cover....remove the cover and you will see 2 square relays...swap these one for the other and then try....these relays will fail..and when it does overheat it WIll shut the engine down.
Posted on Aug 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: Oven fails to reach correct operating temperature.
Clean and working correctly are 2 different things.
Unplug the range. Remove the temp sensor. Use a meter set for ohms and read 1050 to 1150 ohms at room temperature.
If it reads OK replace the electronic control. If it reads bad replace the temp sensor.
Posted on Jan 04, 2010
Testimonial: "Will check temp sensor as advised. Thanks."
  • 32 Answers
SOURCE: how to solve the fuser problem?
Change fuser unit assymbley it will be fine....
Posted on Aug 03, 2010
I have a problem of fuser module (r3) temperature error in xerox workcentre 5755
Can you feel any physical heat from the fuser. Sounds like either the thermistor that controls temperature or the lamp failed.
Sep 15, 2016 | Xerox Office Equipment & Supplies
Optimizing performance in taskalfa 820
When you see "optimizing performance", the machine is going through a cool down cycle and will return to ready after the machine's internal temperature reaches an acceptable amount (usually appears after a large amount of copying). Sometimes I have seen it take as long as 5-10 minutes for the message to clear but if you turn it off before it finishes it's cool down cycle, most of the time the machine immediately shows the message again on display. As mentioned, make sure your filters are clean. I'd also check to ensure your exhaust fans are operational (especially those near fuser area), fuser thermistors clean and in proper position, and ensure machine has proper clearance around the cabinet so it can breath properly.
check the place of the machine.there is not enough cooling temperature for the machine.provide the recommenced temperature 16 to 20 degree.your problem will be solved.
Apr 24, 2014 | Kyocera Ecosys FS-820 Laser Printer 14,499...
Maintenance manual
Jun 17, 2013 | Cars & Trucks
I have a fax machine F550 which is giving me an error message 0550H. Can you please help me to resolve this issue.
i tried looking at the manual. and this is closest thing I could find.
550 9-22 A Standby temperature error 1-Fusing temperature failed to drop to expected level within a given time (15 seconds, 15 minutes, or 25 minutes, depending on mode) after entering standby or lowpower mode. try rebuilding the fuser. hope this helps. goodluck
Apr 14, 2011 | Office Equipment & Supplies
I got the error 50.9 on my hp colorlaser jet 3600 and i've what it said on the screen of the printer and the error it still there. please help me, i need this, my job is in the line. what can i do to make...
Hi hope this helps
the error looks to be low temperature on the fuser
as a repairer of machine I would normally recommend a new fuser unit if you use the machine a lot don't go for a refurbished unit as they just dint last as long but they cost more
hope this helps Ian
50.X FUSER ERROR
alternates with
For help press
A fuser error has occurred.
X Description
1 - low fuser temperature
2 - fuser warmup service
3 - high fuser temperature
4 - faulty fuser
8 - low fuser temperature
(subthermistor
9 - high fuser temperature
(subthermistor)
WARNING: The fuser is HOT. Turn the
printer off and allow it to cool for
approximately 10 minutes before removing
the fuser.
50.1 error - Fuser failure (Abnormally Low
Temperature Main Thermistor), perform the
following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Faulty DC controller PCB. Replace the
DC controller PCB.
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
it if damaged.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
Table 7-3. Numerical printer messages (continued)
338
Mar 24, 2011 | HP LaserJet 3600n Printer
Have a BIZHUB 550 with a C-3724 error on it. I had to select the 450 below as the 550 is not listed.
Fusing abnormally high temperature detection
The fuser section reached a temperature outside of safe operation. You can reset the error by: Turning the main switch off, leave the operation panel switch on, hold down the utility/counter key and turn the main switch on. As the screen loads you will see a black dot in the top right corner, at this point you can release the utility/counter key. The machine will take a minute to load. When the screen loads you will have a key that says "Trouble Reset" press it and you will get a "OK" message. Turn the main power off for 10 seconds and turn back on. If message returns you must replace the fuser. Attempt Trouble reset again at your own risk!! Fusers are a Fire Hazard
Apr 27, 2010 | Konica Minolta bizhub C450P Laser Printer
My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Feb 18, 2010 | Ricoh Aficio SP C811DN Laser Printer
Error code H4-00
It means that your fuser (which melts the toner to the paper) did not reach its proper operating temperature. You will need to have the fuser inspected by a qualified technician to determine the cause. He will also be able to reset the error code and make the machine operable again.
May 03, 2008 | Toshiba e-Studio162D Copier
Blinking number and letter
the fuser is not reaching the proper temperature. Try turning off the power and waiting a few minutes and turning on. If it still fails fuser or power supply needs replacing.
Nov 30, 2006 | Sharp AR-157E Copier
52 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
