It's the smallest gear of the gear train. The current one has deteriorated with age and slips on the motor spindle.
SOURCE: "machine gun clicking" sound - fuser drive/motor gear area
Sometimes the clicking noise can come for the developer cartridge or the drum. you can carefully take them out and see if they turn freely.
SOURCE: drive train slipping
Get someone to help--set the brakes and try to drive it. The other person needs to watch what is turning. If it turns into the differential, but nothing happens coming out on either side, then drain the oil out of, and open the cover on the differential. Look at the drive pinion gear (you can run this for a short time without lubrication), is it turning? That will turn the ring gear which turns the differential unit. If one axle turns, but the other side doesn't, look for a broken axle on the side that turns. If the input pinion gear doesn't turn, look for a broken pinion shaft. Hope this helps!
SOURCE: I am thinking of buying a used Hansol 550 - three
3 years old will more likely to need new set of caps, not all monitors come with built-in speakers. See failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
I would not buy a 3 years old 15", save the money for newer and bigger monitor.
SOURCE: I have bought a Sewland overlocker but there are
Google sewland overlocker and you will see a quilting site that has the manual you need for free. You probably can print it out..
