My pda is saying waiting and won't connect. I opened up the -box and none of the LED's are lit. I attempted to change the RF chanel also, but neither the red or green LED is on, what should I check.
Shuttle83
  • 1139 Answers
SOURCE: Coleman 1500 power inverter has no output
I believe that the actual unit may have other problems and that you will need a schematic to aid in your troubleshooting of this issue. Once you have the schematic and a multiment you can check the voltages to see if things ar as they should be and then we can look at what is happening.
Posted on Sep 08, 2007
  • 1694 Answers
SOURCE: 50ux22ba
Common failure is C702 Capacitor near flyback== 102K/2KV shorted==replace w/102K/3KV generic or Sony part number 1-161-754-00.Also,check E994 open 2 amp pico fuse.
Posted on Oct 09, 2007
jerryg50
  • 1689 Answers
SOURCE: TV WILL NOT TURN ON
The power supply, and or one of the circuit board is defective. The set will require shop service.
Jerry G.
Posted on Jul 26, 2008
SOURCE: LEDS are lit- one red, one green. no display, no boot
SOLVED!
This happing when trying to download a firmware upgrade or config from server and there is a power outgage.
Solution:
Put a file called cp7912r.zup in your tftpserver root. This file can be a valid cisco image, for example, CP7912080001SIP060412A.sbin
Posted on Sep 03, 2008
  • 8 Answers
SOURCE: will not stay on
FIXED IT!!!
So if you have a blinking red protection LED:
Turned out the pico-fuse for the -23V had 130 ohms resistance. Initial continuity test feature on my meter indicated it was good since anything under 200 ohms is continuity. All of this after many hours of frustration... and not understanding why all secondary voltages on the power transformer were at 50% for the 2-3 seconds of power up before shutting down.
The "leaky" pico-fuse turned into resistor allowed enough power to illuminate -23V LED despite voltage being 1/2.
Replaced with new pico-fuse to get true -23V. All other output voltages followed suit and TV is working perfectly.
Don't trust the green LEDs. Measure all voltages and be sure to verify 1 ohm or less for every pico-fuse.
I don't understand how a faulty -23V rail would cause this problem. Feedback is from the +31V rail which powers standby 12V safety regulator, 9v and 5v switched regulators.
Anyways it works now.
Posted on Nov 10, 2008
How do you hook up cords to cable box & television
WELL IT SEEMS U HAVE TWO PROBLEMS :
1ST YOUR rF SIGNAL IS NOT GETTING THRU , THIS IS A ROUND CABLE WITH A SCREW ON END TO IT , THIS ONE MUST 1ST COME INTO YOUR HOME AND GO TO CABLE BOX , THEN LEAVE OUT OF CABLE BOX AND ENTER VCR THEN LEAVE OUT OF VCR AND GO TO RF INPUT OF TV ( HAS TO BE HOOKED THIS WAY WONT WORK ANY OTHER WAY) SET OUTPUT OF VCR TO CHANEL 3 SET OUTPUT OF CABLE BOX TO CHANNEL 3 SET TUNER OF VCR TO CHANEL 3 , AND LAST SET INPUT OF TV TO rf CABLE ,CHANEL 3 , NOW YOU CHANGE CHANELS ON CABLE BOX only
2ND YOUR DVD PLAYER HAS NO RF OUTPUT SO YOU NEED TO CONNECT BY ONE OF THESE MEANS (HDMI, RGB, COMPOSITE) ALL THESE REQUIRE A DIFFERENT CABLE YOU DECIDE , THERE HOOK UP IS PRETTY MUCH ONE WAY SO I WONT ELABORATE ON EACH METHOD , BUT TV NEEDS TO BE SET TO CORESPONDING INPUT TYPE YOU DECIDED ON
Nov 11, 2015 | Magnavox DV220MW9 DVD Player VCR
How do i reboot my handheld handy 8625 pda remote
turn the rs box off also total reboot should do that make sure the red 4 pin plug is connected to the pcb board
Jan 15, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy pda 8265 not working
Have you replaced the 9v battery in the control box recently?
Sep 30, 2009 | Jandy AQUALINK RS TELELINK KIT
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
Rf2 outlet from sky hd box
on your sky remote
services
0 1 select
make sure the rf is set to on
Remember the channel rf number,
go to your television the link is to.
go to menu then setup and then manual tune
select the channel you want to view sky on. normally channel 6 on your analogue
then go to Channel type in whatever the rf setting was on your main sky box then press save.
that is your telly sorted out. if you have a magic eye connected at the link end you should see a red led light lit up.
if not remove the magic eye and connect it straight into the back of your sky box RF2
just to make sure that the eye is not at fault.
hope this helps
ill check in a day or two to see if you need more help.
Cheers
Little Dish Fitter
Nov 14, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
