Question about Fisher Washing Machines
How to reset fisher payel washer after new pump installed
    Top Expert:
  • 867 Answers
If you have fitted a new pump the machine will just work, if it is not then there is an internal fault with the electronic motor controller module.
Posted on May 15, 2017
5 Suggested Answers
  • 93 Answers
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Posted on Jul 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: my Fisher & Payel smart load dryer is not
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Posted on Mar 19, 2010
SOURCE: MY FISHER AND PAYEL GW
I have a Fisher & Paykel GW712 and had same problem and fixed it today the drain pump motor had failed although it worked for 1 full cycle. when I tried to wash a second load the water would not completly clear from the machine I finally replaced the pump and now works correctly the pump is easy to install ensure machine is disconnected from power first
Posted on Mar 28, 2011
hunter19_46m
  • 7482 Answers
SOURCE: My Fisher Payel dryer will start when you press
Hi kfkkaa...
Replace the start switch on your dryer...it is faulty
Please take time to rate me
Posted on Sep 12, 2011
Fisher and Paykel Washer GW 609 when switched on at wall keeps pumping
The best bet is to have an authorized serviceman test the control board for continuity. It is out of phase and cannot reset to the normal start position.
Feb 27, 2014 | Fisher and Paykel Washing Machines
Tip
Fisher & Payel washer wouldn't work
A repairman examined my washer and told me I needed a new drain pump. The washer wouldn't drain the water out after filling. I suggested he check the drain because I had recently washed a rug and suspected the drain as clogged with lint. He took out the drain pump and diagnosed that I needed a new pump. After he left, I watched a youtube video on this problem. They man in the video carefully showed how to remove the drain pump. I then removed the drain pump myself and found an inch size ball of lint that was clogging the drain pump up inside. I removed the lint and reinstalled the same pump and the washer has worked fine ever since. I learned this after an expensive service call fee and he wanted to charge me another $150+ for new drain pump and installation.
on Jan 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
FISHER PAYKEL WASHER GWL11 WONT FILL TANK
Check your diverter valve is in right and working.
Energized valve, water goes over bowl.
Non Energized valve water goes down the drain.
Feb 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
MY FISHER AND PAYEL GW 712 WASHING MEACHAINE IS NOT SPINNING AT ALL
Mar 27, 2011 | Fisher and Paykel (IWL12)
Our drain pump was squealing so when the washer stopped mid-cycle
you will need to make sure that the plug is in the pump properly as if it is not the machine will not turn on, also the pump has a thermal over temp inside it so you need to make sure that it has not popped (it is self resetting unless it is faulty), so check the pump for continuity it should be about 32ohms. Also check the pump housing to make sure there is nothing in there restricting water flow
Jul 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi My fisher payel fridge with the under freezer has a built in ice maker and it has stopped working. What do I need to do to fix it?
Tell me more, why did it suddenly stop? What did you change? Did you turn off electric? Get anything water wise that is new? Did you lower the water pressure coming into your home? Where do you live - house, apartment?
I can't say why it quit, unless you left it running on "make a lot of ice" (some fridges have this option), were out of town and had some electrical issues, went through a big storm or changed the water coming into the fridge. These are the obvious reasons why you'd have an issue.
A little more detail, Please?
Mar 21, 2010 | Fisher and Paykel E522B Stainless Steel...
My Fisher & Payel smart load dryer is not
Hi
Thanks
Rylee
Mar 18, 2010 | Fisher and Paykel Dryers
No power to fisher paykel washer. Replaced pump
Jul 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Dead Fisher & Paykel GWL11 Washer
Plug off the wall; dismantle & clean out your pump. This is if your filter is clean.
Jun 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
